  3. creation of Nwell and Psub in gpdk 090 technology
  • Views 17273
raghavendra ks
raghavendra ks over 10 years ago
Hello i am not able to create the nwell in Layout XL suite in cadence virtuoso 6.16. i am using gpdk 090 technology file . when i try to create via i am getting only vias between metal layers. where is via for nwell and psub. Help me Please
    Use Options->Editor and then change the Default Wire Constraint Group to VirtuosoDefaultExtractorSetup and have the Create Via box set to "Same as Wire" (you could also set the constraint group here to be VirtuosoDefaultExtractorSetup). The default constraint group is VirtuosoDefaultSetup and that only includes the metal layers as valid layers and vias between them.
    Having changed this, you'll then have access to M1_PSUB and M1_NWELL vias from the Create Via form.
