  3. ADEXL: Accessing results via Skill
  • Views 14369
MarkusK
MarkusK over 10 years ago
Hi everybody,
based on ADEXL I've set up an simulation with several output expressions. Now I would like to access the simulation results using skill (for further post processing).
I've already found the way how to access the expression results for scalar results:
oneTest = car(rdbObj->tests())
oneTest->output("OutScalar")->value
==> 5
Unfortunately this fails if the expression is defined as a "list of results" somehow like:
outVector = value(testData point1  ?period period ?xName "cycle"  )
In this case I get:
oneTest->output("OutVector")->value
==> "wave"
Which I cannot process any further. It seems to be a string. Can anyone give me a hint how to get the correct evaluation result without a "recalculation" of "outVector"?
Best Regards,
Markus
