  3. Layer Density Value
  • Views 19905
Layer Density Value
MoMiner1870
MoMiner1870 over 10 years ago
Hello, while using Virtuoso layout is there a way to find the value of layer density?
For example, poly or metal 1 density. I would like to show an actual percentage.
I can see how to check the layer densities in Assura (by selecting check density) but it does not give a value only error or no error.
Also we are using PVS for everything else and would prefer to stick with that tool.
This is for a student lab I am creating, we are using the gpdk45 technology.
Thank you!
  • ColinSutlieff
    ColinSutlieff over 10 years ago
    Hi Daryl,
    Just use the latest version of Virtuoso (IC6.1.7).
    It's under tools->area and density calculator.
    Hope this helps
    Colin
  • MoMiner1870
    Thats great, is that only in 6.1.7?  We are still on 6.1.6.
    Hi Daryl,
    This was available in IC616 as an early adopter feature, but I checked with product engineering and they agreed it's OK to share it. To access it, call the following SKILL function:
    leHiAreaDensity()
  • MoMiner1870
    Thanks alot Andrew.
