  3. creatNetlist with ocean in a specific directory
  • Views 15952
fabriceBG
fabriceBG over 10 years ago
I would like to creat a netlis in a specific directory ‘myDir’
To do so I run
>ocean –nograph <mySrcipt.ocn
with mySrcipt.ocn :
simulator('spectre)
design("myLib" "myCell" "schematic")
envSetVal("asimenv.startup" "projectDir" `string "myDirFullPath")
envSetVal("asimenv.startup" "remoteDir" `string " myDirFullPath ")
createNetlist(?recreateAll t ?display nil)
exit()
The netlist is generated, but in ~/simulation/myCell/spectre/schematic/netlist.scs, even if I set "asimenv.startup" "projectDir
How to generate in myDirFullPath instead of ~/simulation ?
It is probably a matter of precedence, but I don’t find the solution.
Fabrice
    Fabrice,
    The problem is you're setting it after starting the simulation session (i.e. after the simulator() call). Set it before the call to simulator(). It's a "startup" env var, so that's why you need to set it before startup.
  • fabriceBG
    Thanks Andrew,
    Indeed setting the environnent before the starting the session is better.
    Fabrice
