  3. using values from a paramAnalysis (ocean script)
  • Views 14465
HHaller
HHaller over 10 years ago
My aim is to use some values for some calculations from a paramAnalysis in Vituoso via ocean script.
My code look's like
;--------------Parameter-Analysis-------------
points = '( 1  1.5)
tran = paramAnalysis("Signal" ?values points)
paramRun('tran)
selectResult( 'tran )
foreach( x sweepValues()
  selectResult( 'tran x )
  FlipInj = cross( v("vpulse") .250 4 'falling)
  some calculations
sweepValues() -> (1 1.5)
selectResult('tran car( sweepValues() )) -> stdobj@0x17441818
selectResult('tran cdr( sweepValues() )) -> stdobj@0x17441818
Inj = cross( v("vpulse") .250 4 'falling) -> srrWave:0x1a247200
--> Inj contains two values for 1 and 1.5
Unfortunately, selectResult returns not just one value for the first run but it seems to return all values
, i.e. my calculations don't work.
Is there a way to just select the values for the first run, so that cross returns just one value and not a vector?
