  3. QRC version for IC614.500.6
  • Views 15099
magal
magal over 10 years ago
We are working with legacy project that uses IC614-6.
I would like to install QRC and Assura versions but not sure which are the latest compatible ones.
Does anyone know which Assura and QRC will work with my IC614 Version, or alternatively, where can I find this information?
Any Help Will be appreciated!
Matan.
  • Quek
    Quek over 10 years ago
    Hi Matan
    - For Assura, you can use "ASSURA04.12.001, Version: ASSURA41USR2OA_614".
    - For QRC, you can try "EXT14.10.000, Version: EXT14.10-p203". If it does not work, you will have to contact your local Cadence support to get an even older version of EXT package.
    Best regards
    Quek
  • magal
    Thanks!
    Will try and report back
    Matan
  • magal
    O.K. so....Sow far I managed to load Assura almost fine. Upon loading I do get one warning in the CIW:
    *WARNING* Faild to load context file '/software/opt/CDS/ASSURA-614/bin/64bit/etc/context/6.1.4/64bit/sna.cxt'.
    The reson is simple - no such library exist under '/software/opt/CDS/ASSURA-614/bin/'
    Assura lvs seems to run (haven't checked if ran OK yet).
    Is this issue critical? If so, is there any way around that?
    Any Help will be appreciated!
  • Quek
    Hi Matan
    You can ignore the warning on the loading of sna.cxt file. SNA files have been moved from ASSURA to EXT package. The warning message has already been removed in later versions of Assura.
    Best regards
    Quek
  • magal
    Hi Quek,
    Thanks for the reply!
    Assura is then confirmed to be working. Also, is seems that QRC GUI loads fine. I get a bunch of warnings (LVS) and errors (QRC) but I suspect it's because I only verified that the GUI loads, and didn't fully follow Fab's extraction instructions.
    The last annoyance is the fact that, like in our IC616 environment, If I use my predefined software "icfb-module" to load Virtuoso then QRC GUI doesn't load. I'll try to work out with my system which env variable is annying Quantus.
    Until then - many, many thanks!
    Matan
