  3. Manipulate and export data from ViVa
  • Replies 12
  • Views 22713
BaaB
BaaB over 10 years ago
I have two signals as in the picture below.
I would like to measure some information and export them to a table or a file something like this:
Pulse width     fall time
614n                738n
696n                686n
581n                660n
660n                672n
I am wondering if there is a way to do that. It would be a great help. Otherwise, I have to do it manually with hundreds points.
Thank you.
    You can use the cross() function to measure the zero-crossing in each cycle - no need to write something custom. Actually it might be a slight problem, because if there is ringing, it will cross zero multiple times in each cycle, so you might need to adapt it after all.
    Anyway, I really can't spend longer on this - it seems a very specific requirement.
    I did update the code so that all the arguments are keywords (and fixed a couple of bugs in the family waveform handling). I didn't re-create the re-formatted version of the code, sorry (it's only slightly different from the previous version though).
    In IC617 you can use the button in the calculator in the function panel to read this in and define a form for it (note you'll have to remove the type check string "gSSSfSSff" from the end of the arguments - this confuses the template builder currently - I'm just reporting that as a bug to R&D). However, you weren't using IC617 so I won't go into the details.
    /* abGetCyclePeaks.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Mar 23, 2016
    Modified   Mar 24, 2016
    By         A.D.Beckett
    Function to calculate the peak values (or times of peak values)
    within each period. Has some tolerances built in so that it should
    detects when it first reaches the peak and filters out numerical
    noise.
    Example - measure fall time (peak to peak) in each period:
    abGetCyclePeaks(v("ramp" ?result 'tran) ?minMax "max" ?yValues "x")-
        abGetCyclePeaks(v("ramp" ?result 'tran) ?minMax "min" ?yValues "x")
    SCCS Info: @(#) abGetCyclePeaks.il 03/24/16.09:15:02 1.2
    *   (abGetCyclePeaks wave [?crossType "rising"] [?minMax "max"]    *
    * [?mode "auto"] [?threshold 0.0] [?yValues "y"] [?xName "cycle"]  *
    *                  [?reltol 1e-3] [?abstol 1e-6])                  *
    *     For each cycle - identified by the rising or falling (or     *
    *     either, but that's not so likely to be used) crossing of     *
    *     the threshold (which is controlled by the ?mode argument     *
    *  "auto" means automatic, "user" means as specified) - find the   *
    * "min" or "max" value of the signal within the cycle. In order to *
    * filter out numerical noise on the signal influencing the precise *
    *     position of the peak, only look at changes bigger than a     *
    *   reltol+abstol type delta from the previously found peak. The   *
    *   resulting waveform can be plotted versus "cycle" or "time",    *
    *    and the yValues can be either the y or x values at the peak.  *
    (defun abGetCyclePeaks (wave @key (crossType "rising") (minMax "max")
                                 (mode "auto") (threshold 0.0) (yValues "y")
                                 (xName "cycle") (reltol 1e-3) (abstol 1e-6)
                                 "gSSSfSSff")
      (cond
        ((drIsWaveform wave)
         (let (xVec yVec len outX outY newXVec newYVec newWave cycleNum lastY
                    thisY localPeakX localPeakY direction func absdelta tolerance)
           ; Validate the arguments to ensure they are valid strings
           (foreach validInfo
                   (crossType ,(setq crossType (get_string crossType))
                              ("rising" "falling" "either"))
                   (minMax ,(setq minMax (get_string minMax)) ("min" "max"))
                   (?mode ,(setq mode (get_string mode)) ("auto" "user"))
                   (?xName ,(setq xName (get_string xName)) ("cycle" "time"))
                   (?yValues ,(setq yValues (get_string yValues)) ("y" "x"))
                 (unless (member (cadr validInfo) (caddr validInfo))
                   (error "abGetCyclePeaks: %s argument must be one of \"%s\": %L\n"
                          (car validInfo)
                          (buildString (caddr validInfo) "\",\"")
                          (cadr validInfo))
           (when (equal mode "auto")
             (setq threshold (average wave)))
           (setq func (if (equal minMax "max") 'greaterp 'lessp))
           (setq xVec (drGetWaveformXVec wave))
           (setq yVec (drGetWaveformYVec wave))
           (setq len (drVectorLength xVec))
           (setq cycleNum 0)
           (setq lastY (drGetElem yVec 0))
           (setq localPeakY lastY)
           (setq localPeakX (drGetElem xVec 0))
           ; Iterate through all the points
           (for i 1 (sub1 len)
                (setq thisY (drGetElem yVec i))
                ; Determine if this is a transition, and if so, which direction
                (setq direction
                      (cond
                        ((and (lessp lastY threshold)
                              (geqp thisY threshold)) "rising")
                        ((and (geqp lastY threshold)
                              (lessp thisY threshold)) "falling")
                        (t nil)))
                ; Assuming it's a crossing in the right direction, record
                ; the peak in that cycle (doesn't do it before the first
                ; transition though)
                (if (or (equal crossType direction)
                        (and (equal crossType "either") direction))
                  (progn
                    (when (greaterp cycleNum 0)
                      (setq outX
                            (tconc outX (if (equal xName "cycle") cycleNum
                                          localPeakX)))
                      (setq outY (tconc outY
                                        (if (equal yValues "y")
                                          localPeakY localPeakX)))
                    (setq localPeakX (drGetElem xVec i))
                    (setq localPeakY thisY)
                    (postincrement cycleNum)
                  ; Otherwise see if the peak has been exceeded
                  (when (funcall func thisY localPeakY)
                    (setq absdelta (abs (difference thisY lastY)))
                    (setq tolerance (plus (times (max (abs thisY) (abs lastY))
                                                 reltol) abstol))
                    (when (greaterp absdelta tolerance)
                (setq lastY thisY)
           ; Construct output vectors and waveforms with the right
           ; attributes
           (setq newXVec (drCreateVec
                           (if (equal xName "cycle") 'intlong 'double) (car outX)))
           (setq newYVec (drCreateVec 'double (car outY)))
           (putpropq newXVec (if (equal xName "cycle") "" (getq xVec units)) units)
           (putpropq newXVec
                     (if (equal xName "cycle") "cycle" (getq xVec name)) name)
           (putpropq newYVec
                       (getq yVec units)
                       (getq xVec units))
                     units)
           (putpropq newYVec
                       (getq yVec name)
                       (getq xVec name))
                     name)
           (setq newWave (drCreateWaveform newXVec newYVec))
           (famSetExpr newWave
                       `(abGetCyclePeaks ,(famGetExpr wave)
                                         ?crossType ,crossType
                                         ?minMax ,minMax
                                         ?mode ,mode ?threshold ,threshold
                                         ?yValues yValues ?xName ,xName
                                         ?reltol ,reltol ?abstol ,abstol))
           newWave
        ((famIsFamily wave)
         (famMap 'abGetCyclePeaks ?crossType crossType ?minMax minMax ?mode mode
                 ?threshold threshold ?yValues yValues ?xName xName
                 ?reltol reltol ?abstol abstol)
        (t
          (error "abGetCyclePeaks: Cannot handle %L\n" wave)
  • BaaB
    Thank you for the help! I am studying SKILL so hope I can write it myself.
