  3. Deep NWell for NMOS is connected to VSS, how to connect...
  • Views 20389
Deep NWell for NMOS is connected to VSS, how to connect the floating substrate
afridimcci
afridimcci over 10 years ago
Hello everyone,
I have designed a circuit which has deep nwell NMOS devices so that the NMOS is isolated from the rest of the substrate. The NMOS body is connected to "VSS". Now the problem is how to connect the floating global p-substrate surrounding the circuit to a different ground node and how to name it so that it clears DRC and LVS checks. I have tried connecting it to a different ground pin but the ERC shows that the psub is still floating.
    Given that this is a rather technology-specific question, it would help considerably to know what technology you're using! Maybe somebody who is familiar with that process, the rules, and how the physical verification is set up will then be able to help you.
    Similarly, it would be rather important to know what physical verification tool you're using.
    Kindest Regards,
  • afridimcci
    It is TSMC 130nm pdk and I am using Calibre LVS for verification.
