  3. How to use the 'gmin_check' option & set Option dc_pivot_check...
  • Views 18167
How to use the 'gmin_check' option & set Option dc_pivot_check=yes
jdp721
jdp721 over 10 years ago
Hi.
Two common warning messages obtained from Cadence ADE DC-analysis (also in Transient) are:
(1) "....Use the `gmin_check' option to eliminate or expand this report.
(2) "....Bad pivoting is found during DC analysis. Option dc_pivot_check=yes is recommended for possible improvement of convergence."
A screenshot of the simulation log showing this is attached.
Can you please tell how to set these options? I searched in the DC and Transient analyses Options window but couldn't locate any corresponding entity!
Thanks.
  • Frank Wiedmann
    Frank Wiedmann over 10 years ago +1
    No, dc_pivot_check and pivotdc are not the same. Typing "spectre -h options" at the Unix command line shows 119 pivotdc=no Use numeric pivoting on every iteration of DC analysis. Possible values are…
    Andrew Beckett over 10 years ago +1
    The dc_pivot_check is a separate option, and wasn't added to the UI until IC616 ISR10 (6.1.6.500.10). If you want to control this before then you can add: dc_pivot_check=yes to the Additional arguments…
  • Frank Wiedmann
    You can find them under Simulation -> Options -> Analog in the Algorithm tab.
  • jdp721
    Hello Frank!
    Thanks for your reply.
    I searched for those options in "Simulator Options" (attached screenshot), and have two questions:
    1. I couldn't locate the "dc_pivot_check=yes" option - is it same as the "pivotdc" option displayed?
    2. there are 4 available options for "gmin_check" : max_v_only, max_only, no, and all - is it possible for you to tell which option to check?
    With regards,
    Jdp.
  • Frank Wiedmann
                              analysis. Possible values are no and yes.
    120     dc_pivot_check=no
                              During DC analysis, the numeric pivoting is only
                              performed when bad pivot is detected. Possible values
                              are no and yes.
    In recent versions of IC616, dc_pivot_check appears in the form directly below pivotdc. However, as a workaround, you can enter dc_pivot_check=yes in the field "Additional arguments" under the Miscellaneous tab.
    Changing gmin_check will only influence the reporting in the log file but not the problem itself. I would recommend that you either leave it at its default value (which is max_v_only) or set it to all for an even more detailed report.
    The dc_pivot_check is a separate option, and wasn't added to the UI until IC616 ISR10 (6.1.6.500.10). If you want to control this before then you can add: dc_pivot_check=yes to the Additional arguments field at the bottom of the Miscellaneous tab on the Simulation->Options->Analog form.
    For the gmin_check, if you just want to suppress the warnings, you can set this to no.
    Most of the time I just ignore these gmin_check messages though.
  • jdp721
    THANK YOU very much Frank and Andrew...the crisp explanation was exactly the info what was needed :)
    Jdp.
