  3. QRC Questions - *Error* eval: undefined function
  • Views 2346
soha
soha over 10 years ago
I am having trouble running QRC. I am currently using Cadence Virtuoso 6.1.6 with FreePDK3D45. I am trying to do the extraction from the layout. I got the following error:
*Error* eval: undefined function - _vfoIsAdvancedNodeEnabled
*WARNING* Technology must be specified!
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): ***** Quantus QRC terminated abnormally *****
I could not find _vfoIsAdvancedNodeEnabled in any file. Could you please help me solve this problem?
Thanks in advance
    You didn't mention the important information - which QRC and Assura version (if indeed you're using Assura) you're using.
    I believe this problem affected the Assura-QRC flow and was fixed in Assura  4.1_USR4_HF6.
  • soha
    Hi Andrew
    thank you for your response. I am using Assura 4.1 USR4 HF1 and EXT 14.10.
    Regards
    Soha
