  3. How to find the intersection point of two lines?
  • Views 22795
BaaB
BaaB over 10 years ago
In ViVA, IC6.17, if we plot two lines and they cross each other at one point. Is there a way to know exact the intersection point of two lines?
Thank you.
    Andrew Beckett over 10 years ago +1
    Use the calculator. Subtract one signal from the other, and then use the cross function on the result. If you need to know the y-value of the intersection, use this cross expression as the argument to…
    Use the calculator. Subtract one signal from the other, and then use the cross function on the result. If you need to know the y-value of the intersection, use this cross expression as the argument to the value function on one of the two input signals.
