  3. How can I find the Rule file for ts18scl_prim Scl_pdk in...
  • Views 15607
How can I find the Rule file for ts18scl_prim Scl_pdk in cadence?
Uday Reddy
Uday Reddy over 10 years ago
I had drawn a wire in schematic as well as in Layout in scl_pdk Library. For verifying DRC I did not get the Rule file and Rule Library of that ts18scl_prim. I have checked in the terminal of that files
Let say,
evince. /scl_pdk/design_kit/drclvs_rsf/DRC_TS18SL_SCL_CALIBRE
I got a Pdf and I copied a link in the preference -> sublimed link in it.
then I copied it in the rule file. But it doesn't wok. It says that Rule file is failed and it does not have this DRC file and it is Empty. So Please help me in this.
Reddy.
    This question doesn't make sense. I have no idea what "I copied a link in the preference -> sublimed link it it" means. Also, you're talking about Calibre (which isn't a Cadence tool - it's from Mentor Graphics).
    I would suggest that you ask your supervisor or you contact whoever provided this design kit - since this is related to files within a specific design kit. If you're going to ask questions here, please read the forum guidelines, because poorly framed questions like this are highly unlikely to be answerable.
    BTW, sending me a friend request saying that you have "important doubts in cadence" (whatever that means) isn't going to get you an answer any quicker (I generally decline friend requests on these forums unless I have explicitly asked for them) because I don't have the bandwidth to answer direct questions from individuals the world over (I do all this in my spare time).
    Kindest Regards,
