  3. Error messages while running ocean script
  • Views 16426
saikatc
saikatc over 10 years ago
I am using ocean scripts to automate the parametric simulation in spectre. Though it is returning result. Still I observe some error messages which are as follows.
1.
Delete psf data in /homes/schatterjee/subvt_28/SUBVT28CORE_test/simulation/lslh_28nm_lvt_test_new/spectre/schematic/v_supply=1/psf.
*WARNING* asiiEvalDesignValList: problem with variable vddh
*Error* in the Design Variables. AEL's message: unspecified
syntax error:
simulate...
2.
spectre completes with 0 errors, 11 warnings, and 16 notices.
INFO (ADE-3071): Simulation completed successfully.
reading simulation data...
...successful.
...successful.
*Error* <Initial> argument should be a valid number
I am bit curious about those error messages. I will highly appreciate if somebody can explain me a bit.
Regards
Saikat
    Not without seeing your OCEAN script...
  • saikatc
    here is the script.
    simulator( 'spectre )
    design( "/homes/schatterjee/subvt_28/SUBVT28CORE_test/simulation/lslh_28nm_lvt_test_new/spectre/schematic/netlist/netlist")
    resultsDir( "/homes/schatterjee/subvt_28/SUBVT28CORE_test/simulation/lslh_28nm_lvt_test_new/spectre/schematic" )
    modelFile(
    '("/homes/schatterjee/subvt_28/SUBVT28CORE_test/corners.scs" "")
    definitionFile(
    "models.scs"
    analysis('tran ?stop "2u" )
    analysis('dc ?dev "/V1" ?param "dc" ?start "0"
    ?stop "1" )
    desVar( "v_supply" 200m )
    desVar( "c" 4f )
    desVar( "vddh" "1V" )
    desVar( "ln1" 48n )
    desVar( "ln2" 48n )
    desVar( "lp1" 600n )
    desVar( "lp2" 48n )
    desVar( "lp3" 60n )
    desVar( "wn1" 120n )
    desVar( "wn2" 360n )
    desVar( "wp1" 500n )
    desVar( "wp2" 80n )
    desVar( "wp3" 80n )
    envOption(
    'analysisOrder list("tran" "dc")
    save( 'i "/V2/MINUS" "/V0/MINUS" "/V1/MINUS" )
    temp( 27 )
    run()
    paramAnalysis("v_supply" ?start 200m ?stop 1000m ?step 100m)
    paramRun()
    plot(getData("/A" ?result "tran") getData("/Z" ?result "tran"))
    plot(getData("/A" ?result "dc") getData("/Z" ?result "dc") )
    i_tr_r = integ((IT("/V2/MINUS") + IT("/V0/MINUS") + IT("/V1/MINUS")) cross(v("/A" ?result "tran") 0.03 1 "rising" nil nil) cross(v("/A" ?result "tran") 0.27 1 "rising" nil nil))
    plot( i_tr_r ?expr '( "i_tr_r" ) )
    tr_r = ((0.3 * integ((IT("/V2/MINUS") + IT("/V1/MINUS")) 5e-07 6e-07)) + (1 * integ(IT("/V0/MINUS") 5e-07 6e-07)))
    plot( tr_r ?expr '( "tr_r" ) )
    power_stat = 1e12 * ((value(i("/V1/MINUS" ?result "dc"), 0m) +
    value(i("/V1/MINUS" ?result "dc"), vddl) +
    value(i("/V2/MINUS" ?result "dc"), 0m) +
    value(i("/V2/MINUS" ?result "dc"), vddl))*vddl +
    (value(i("/V0/MINUS" ?result "dc"), 0m) +
    value(i("/V0/MINUS" ?result "dc"), vddl))*ymax(v("/vdd1" ?result "tran")))/2
    plot(power_stat ?expr '("power_stat"))
    Regards
    Saikat
    Hi Saikat,
    The first problem (and maybe the second) are almost certainly because of:
    There shouldn't be a "V" in the value. You can't add units (by units I don't mean suffix operators, but SI units). So just do:
    desVar("vddh" "1")
