  3. Bad return status from RCX script generator. Status 256...
  • Views 16720
Bad return status from RCX script generator. Status 256 (URGENT)
harinarain
harinarain over 10 years ago
i am running QRC after DRC and LVS and i'm repeatedly getting this error. Please help me urgently. I am a UTD student anf my project is at stake. PLEASE.
  Cadence Extraction QRC - Parasitic Extractor - Version 9.1.3-p005 Mon Jul
26 14:26:09 PDT 2010
                            Copyright 2010 Cadence Design Systems, Inc.
INFO (EXTQRCXOPT-249) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
 /proj/cad/cadence/assura-5141-3.20.001.lnx86/tools/assura/bin/avRCXxref /home/eng/h/hxr150330/cad/cadence/LVS_RUN/xor2lvs/__qrc.rcx_cmd
@(#)$CDS: avRCXxref version av3.2:Production:dfII5.1.41:5.10.41.500.5.105 07/13/2008 03:23 (logavt05) $
sub-version 3.2, integ signature 2008-07-13-0333
run on engnx01.utdallas.edu at Mon Apr 11 19:47:25 2016
Reading rsf
INFO (LBRCXU-114): Finished /proj/cad/cadence/assura-5141-3.20.001.lnx86/tools/assura/bin/avRCXxref
INFO (LBRCXM-630): Starting extraction...
WARNING (RCXSPIC-28014): ?extractMosDiffusionAP option will be retired in the next release.
Forking:  /proj/cad/cadence/ext.lnx86/tools.lnx86/extraction/bin/32bit//capgen -techdir /proj/cad/library/mosis/IBM_PDK/cmrf8sf/V1.8.0.4DM/Assura/QRC/41 -lvs /home/eng/h/hxr150330/cad/cadence/LVS_RUN/xor2lvs.xcn -p2lvs /proj/cad/library/mosis/IBM_PDK/cmrf8sf/V1.8.0.4DM/Assura/QRC/41/qrcTechFile -sw3d -auto_reorder_off -encrypt -exclude_gate_res -length_units meters -lexclude PC -canonical_res_caps -add_via_effect M1,N_SOURCE_DRAIN -cap_ground_layer substrate -p PC,allGate,N_SOURCE_DRAIN -dsub nfet_sd,pfet_sd,nfRF_drain,nfRF_source,pfRF_drain,pfRF_source,pwell,nw,substrate -blocking pc_model,STI_GOX,N_SOURCE_DRAIN,PC -blocking m1_model,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking m2_model,STI_GOX,N_SOURCE_DRAIN,PC,M1,M2 -blocking ha_var_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking ha_var2_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking mosvar_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking mosvar_dgx,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking diff_decap,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking diff_ncap,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking deCap_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking deCap_dgx,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking sbd,STI_GOX,N_SOURCE_DRAIN,M1 -blocking RF_BULK:0.12,N_SOURCE_DRAIN,STI_GOX,M1,PC,M2 -res_blocking RF_BULK:0.12,m2_parasitic -blocking rcx_pfet_blockage,N_SOURCE_DRAIN,STI_GOX,M1,PC,M2 -res_blocking rcx_pfet_blockage,m2_parasitic -blocking kq_dev_bb,STI_GOX,N_SOURCE_DRAIN,K4 -blocking kq_dev_sx,STI_GOX,N_SOURCE_DRAIN,K4 -blocking kq_term:0.5,STI_GOX,N_SOURCE_DRAIN,K4 -blocking l1_dev_bb,STI_GOX,N_SOURCE_DRAIN,L1 -blocking l1_dev_sx,STI_GOX,N_SOURCE_DRAIN,L1 -blocking l1_term:1.0,STI_GOX,N_SOURCE_DRAIN,L1 -blocking PCRES_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking PCRES_term,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking PCRES_comp_term,STI_GOX,N_SOURCE_DRAIN,PC,M1 -res_blocking PCRES_term,pc_parasitic,m1_parasitic -res_blocking PCRES_comp_term,pc_parasitic,m1_parasitic -res_blocking PCRES_dev,pc_parasitic,m1_parasitic -blocking bondPad_top,STI_GOX,N_SOURCE_DRAIN,M1,M2,M3,M4,MQ,LY,E1,MA -res_blocking bondPad_top,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -blocking vpp_top1,M1 -blocking vpp_top2,M1,M2 -blocking vpp_top3,M1,M2,M3 -blocking vpp_top4,M1,M2,M3,M4 -blocking vpp_tnw1,M1 -blocking vpp_tnw2,M1,M2 -blocking vpp_tnw3,M1,M2,M3 -blocking vpp_tnw4,M1,M2,M3,M4 -blocking vpp_tpw1,M1 -blocking vpp_tpw2,M1,M2 -blocking vpp_tpw3,M1,M2,M3 -blocking vpp_tpw4,M1,M2,M3,M4 -res_blocking vpp_top1,m1_parasitic -res_blocking vpp_top2,m1_parasitic,m2_parasitic -res_blocking vpp_top3,m1_parasitic,m2_parasitic,m3 -res_blocking vpp_top4,m1_parasitic,m2_parasitic,m3,m4 -res_blocking vpp_tnw1,m1_parasitic -res_blocking vpp_tnw2,m1_parasitic,m2_parasitic -res_blocking vpp_tnw3,m1_parasitic,m2_parasitic,m3 -res_blocking vpp_tnw4,m1_parasitic,m2_parasitic,m3,m4 -res_blocking vpp_tpw1,m1_parasitic -res_blocking vpp_tpw2,m1_parasitic,m2_parasitic -res_blocking vpp_tpw3,m1_parasitic,m2_parasitic,m3 -res_blocking vpp_tpw4,m1_parasitic,m2_parasitic,m3,m4 -blocking DI_diode,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking DI_VPNP,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking al_MIM_bot,HY,QY,LY -blocking al_MIM2_bot,HY,QY,LY -res_blocking TL2_MQ_M4,mq,m4 -res_blocking TL2_MQ_M3,mq,m3 -res_blocking TL2_MQ_M2,mq,m2_parasitic -res_blocking TL2_MQ_M1,mq,m1_parasitic -res_blocking TL2_MA_MQ,ma,mq -res_blocking TL2_MA_M4,ma,m4 -res_blocking TL2_MA_M3,ma,m3 -res_blocking TL2_MA_M2,ma,m2_parasitic -res_blocking TL2_MA_M1,ma,m1_parasitic -res_blocking TL2_MA_LY,ma,ly -res_blocking TL2_MA_E1,ma,e1 -res_blocking TL2_M4_M3,m4,m3 -res_blocking TL2_M4_M2,m4,m2_parasitic -res_blocking TL2_M4_M1,m4,m1_parasitic -res_blocking TL2_M3_M2,m3,m2_parasitic -res_blocking TL2_M3_M1,m3,m1_parasitic -res_blocking TL2_M2_M1,m2_parasitic,m1_parasitic -res_blocking TL2_LY_MQ,ly,mq -res_blocking TL2_LY_M4,ly,m4 -res_blocking TL2_LY_M3,ly,m3 -res_blocking TL2_LY_M2,ly,m2_parasitic -res_blocking TL2_LY_M1,ly,m1_parasitic -res_blocking TL2_E1_MQ,e1,mq -res_blocking TL2_E1_M4,e1,m4 -res_blocking TL2_E1_M3,e1,m3 -res_blocking TL2_E1_M2,e1,m2_parasitic -res_blocking TL2_E1_M1,e1,m1_parasitic -res_INFO (LBMISC-215205):
*** Cadence Extraction QRC Techgen -trans VERSION 9.1 Linux 32 bit - (Tue Aug  3 12:34:43 PDT 2010)  ***
INFO (CAPGEN-41199):
Techgen -trans results will be written to directory: /home/eng/h/hxr150330/cad/cadence/LVS_RUN/xor2lvs
INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
 /proj/cad/cadence/ext.lnx86/tools.lnx86/extraction/bin/32bit//capgen -techdir /proj/cad/library/mosis/IBM_PDK/cmrf8sf/V1.8.0.4DM/Assura/QRC/41 -lvs /home/eng/h/hxr150330/cad/cadence/LVS_RUN/xor2lvs.xcn -p2lvs /proj/cad/library/mosis/IBM_PDK/cmrf8sf/V1.8.0.4DM/Assura/QRC/41/qrcTechFile -sw3d -auto_reorder_off -encrypt -exclude_gate_res -length_units meters -lexclude PC -canonical_res_caps -add_via_effect M1,N_SOURCE_DRAIN -cap_ground_layer substrate -p PC,allGate,N_SOURCE_DRAIN -dsub nfet_sd,pfet_sd,nfRF_drain,nfRF_source,pfRF_drain,pfRF_source,pwell,nw,substrate -blocking pc_model,STI_GOX,N_SOURCE_DRAIN,PC -blocking m1_model,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking m2_model,STI_GOX,N_SOURCE_DRAIN,PC,M1,M2 -blocking ha_var_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking ha_var2_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking mosvar_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking mosvar_dgx,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking diff_decap,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking diff_ncap,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking deCap_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking deCap_dgx,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking sbd,STI_GOX,N_SOURCE_DRAIN,M1 -blocking RF_BULK:0.12,N_SOURCE_DRAIN,STI_GOX,M1,PC,M2 -res_blocking RF_BULK:0.12,m2_parasitic -blocking rcx_pfet_blockage,N_SOURCE_DRAIN,STI_GOX,M1,PC,M2 -res_blocking rcx_pfet_blockage,m2_parasitic -blocking kq_dev_bb,STI_GOX,N_SOURCE_DRAIN,K4 -blocking kq_dev_sx,STI_GOX,N_SOURCE_DRAIN,K4 -blocking kq_term:0.5,STI_GOX,N_SOURCE_DRAIN,K4 -blocking l1_dev_bb,STI_GOX,N_SOURCE_DRAIN,L1 -blocking l1_dev_sx,STI_GOX,N_SOURCE_DRAIN,L1 -blocking l1_term:1.0,STI_GOX,N_SOURCE_DRAIN,L1 -blocking PCRES_dev,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking PCRES_term,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking PCRES_comp_term,STI_GOX,N_SOURCE_DRAIN,PC,M1 -res_blocking PCRES_term,pc_parasitic,m1_parasitic -res_blocking PCRES_comp_term,pc_parasitic,m1_parasitic -res_blocking PCRES_dev,pc_parasitic,m1_parasitic -blocking bondPad_top,STI_GOX,N_SOURCE_DRAIN,M1,M2,M3,M4,MQ,LY,E1,MA -res_blocking bondPad_top,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -blocking vpp_top1,M1 -blocking vpp_top2,M1,M2 -blocking vpp_top3,M1,M2,M3 -blocking vpp_top4,M1,M2,M3,M4 -blocking vpp_tnw1,M1 -blocking vpp_tnw2,M1,M2 -blocking vpp_tnw3,M1,M2,M3 -blocking vpp_tnw4,M1,M2,M3,M4 -blocking vpp_tpw1,M1 -blocking vpp_tpw2,M1,M2 -blocking vpp_tpw3,M1,M2,M3 -blocking vpp_tpw4,M1,M2,M3,M4 -res_blocking vpp_top1,m1_parasitic -res_blocking vpp_top2,m1_parasitic,m2_parasitic -res_blocking vpp_top3,m1_parasitic,m2_parasitic,m3 -res_blocking vpp_top4,m1_parasitic,m2_parasitic,m3,m4 -res_blocking vpp_tnw1,m1_parasitic -res_blocking vpp_tnw2,m1_parasitic,m2_parasitic -res_blocking vpp_tnw3,m1_parasitic,m2_parasitic,m3 -res_blocking vpp_tnw4,m1_parasitic,m2_parasitic,m3,m4 -res_blocking vpp_tpw1,m1_parasitic -res_blocking vpp_tpw2,m1_parasitic,m2_parasitic -res_blocking vpp_tpw3,m1_parasitic,m2_parasitic,m3 -res_blocking vpp_tpw4,m1_parasitic,m2_parasitic,m3,m4 -blocking DI_diode,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking DI_VPNP,STI_GOX,N_SOURCE_DRAIN,PC,M1 -blocking al_MIM_bot,HY,QY,LY -blocking al_MIM2_bot,HY,QY,LY -res_blocking TL2_MQ_M4,mq,m4 -res_blocking TL2_MQ_M3,mq,m3 -res_blocking TL2_MQ_M2,mq,m2_parasitic -res_blocking TL2_MQ_M1,mq,m1_parasitic -res_blocking TL2_MA_MQ,ma,mq -res_blocking TL2_MA_M4,ma,m4 -res_blocking TL2_MA_M3,ma,m3 -res_blocking TL2_MA_M2,ma,m2_parasitic -res_blocking TL2_MA_M1,ma,m1_parasitic -res_blocking TL2_MA_LY,ma,ly -res_blocking TL2_MA_E1,ma,e1 -res_blocking TL2_M4_M3,m4,m3 -res_blocking TL2_M4_M2,m4,m2_parasitic -res_blocking TL2_M4_M1,m4,m1_parasitic -res_blocking TL2_M3_M2,m3,m2_parasitic -res_blocking TL2_M3_M1,m3,m1_parasitic -res_blocking TL2_M2_M1,m2_parasitic,m1_parasitic -res_blocking TL2_LY_MQ,ly,mq -res_blocking TL2_LY_M4,ly,m4 -res_blocking TL2_LY_M3,ly,m3 -res_blocking TL2_LY_M2,ly,m2_parasitic -res_blocking TL2_LY_M1,ly,m1_parasitic -res_blocking TL2_E1_MQ,e1,mq -res_blocking TL2_E1_M4,e1,m4 -res_blocking TL2_E1_M3,e1,m3 -res_blocking TL2_E1_M2,e1,m2_parasitic -res_blocking TL2_E1_M1,e1,m1_parasitic -res_blocking TL2_E1_LY,e1,ly -res_blocking TL1_MQ_M4,mq,m4 -res_blocking TL1_MQ_M3,mq,m3 -res_blocking TL1_MQ_M2,mq,m2_parasitic -res_blocking TL1_MQ_M1,mq,m1_parasitic -res_blocking TL1_MA_MQ,ma,mq -res_blocking TL1_MA_M4,ma,m4 -res_blocking TL1_MA_M3,ma,m3 -res_blocking TL1_MA_M2,ma,m2_parasitic -res_blocking TL1_MA_M1,ma,m1_parasitic -res_blocking TL1_MA_LY,ma,ly -res_blocking TL1_MA_E1,ma,e1 -res_blocking TL1_M4_M3,m4,m3 -res_blocking TL1_M4_M2,m4,m2_parasitic -res_blocking TL1_M4_M1,m4,m1_parasitic -res_blocking TL1_M3_M2,m3,m2_parasitic -res_blocking TL1_M3_M1,m3,m1_parasitic -res_blocking TL1_M2_M1,m2_parasitic,m1_parasitic -res_blocking TL1_LY_MQ,ly,mq -res_blocking TL1_LY_M4,ly,m4 -res_blocking TL1_LY_M3,ly,m3 -res_blocking TL1_LY_M2,ly,m2_parasitic -res_blocking TL1_LY_M1,ly,m1_parasitic -res_blocking TL1_E1_MQ,e1,mq -res_blocking TL1_E1_M4,e1,m4 -res_blocking TL1_E1_M3,e1,m3 -res_blocking TL1_E1_M2,e1,m2_parasitic -res_blocking TL1_E1_M1,e1,m1_parasitic -res_blocking TL1_E1_LY,e1,ly -blocking TL2_MQ_M4,MQ,M4 -blocking TL2_MQ_M3,MQ,M3 -blocking TL2_MQ_M2,MQ,M2 -blocking TL2_MQ_M1,MQ,M1 -blocking TL2_MA_MQ,MA,MQ -blocking TL2_MA_M4,MA,M4 -blocking TL2_MA_M3,MA,M3 -blocking TL2_MA_M2,MA,M2 -blocking TL2_MA_M1,MA,M1 -blocking TL2_MA_LY,MA,LY -blocking TL2_MA_E1,MA,E1 -blocking TL2_M4_M3,M4,M3 -blocking TL2_M4_M2,M4,M2 -blocking TL2_M4_M1,M4,M1 -blocking TL2_M3_M2,M3,M2 -blocking TL2_M3_M1,M3,M1 -blocking TL2_M2_M1,M2,M1 -blocking TL2_LY_MQ,LY,MQ -blocking TL2_LY_M4,LY,M4 -blocking TL2_LY_M3,LY,M3 -blocking TL2_LY_M2,LY,M2 -blocking TL2_LY_M1,LY,M1 -blocking TL2_E1_MQ,E1,MQ -blocking TL2_E1_M4,E1,M4 -blocking TL2_E1_M3,E1,M3 -blocking TL2_E1_M2,E1,M2 -blocking TL2_E1_M1,E1,M1 -blocking TL2_E1_LY,E1,LY -blocking TL1_MQ_M4,MQ,M4 -blocking TL1_MQ_M3,MQ,M3 -blocking TL1_MQ_M2,MQ,M2 -blocking TL1_MQ_M1,MQ,M1 -blocking TL1_MA_MQ,MA,MQ -blocking TL1_MA_M4,MA,M4 -blocking TL1_MA_M3,MA,M3 -blocking TL1_MA_M2,MA,M2 -blocking TL1_MA_M1,MA,M1 -blocking TL1_MA_LY,MA,LY -blocking TL1_MA_E1,MA,E1 -blocking TL1_M4_M3,M4,M3 -blocking TL1_M4_M2,M4,M2 -blocking TL1_M4_M1,M4,M1 -blocking TL1_M3_M2,M3,M2 -blocking TL1_M3_M1,M3,M1 -blocking TL1_M2_M1,M2,M1 -blocking TL1_LY_MQ,LY,MQ -blocking TL1_LY_M4,LY,M4 -blocking TL1_LY_M3,LY,M3 -blocking TL1_LY_M2,LY,M2 -blocking TL1_LY_M1,LY,M1 -blocking TL1_E1_MQ,E1,MQ -blocking TL1_E1_M4,E1,M4 -blocking TL1_E1_M3,E1,M3 -blocking TL1_E1_M2,E1,M2 -blocking TL1_E1_M1,E1,M1 -blocking TL1_E1_LY,E1,LY -res_blocking SYMINDP_MA_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking SYMINDP_MA_LY_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking SYMINDP_MA_LY_BF,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking SYMINDP_MA_BF,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking INDS_MA_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking INDS_MA_BF,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking INDP_MA_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking INDP_MA_BF,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking IND_MA_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -res_blocking IND_MA_BF,m1_parasitic,m2_parasitic,m3,m4,mq,ly,e1,ma -blocking SYMINDP_MA_M1,STI_GOX,N_SOURCE_DRAIN,MA,M1,M2,M3,M4 -blocking SYMINDP_MA_LY_M1,STI_GOX,N_SOURCE_DRAIN,MA,LY,M1,M2,M3,M4 -blocking SYMINDP_MA_LY_BF,STI_GOX,N_SOURCE_DRAIN,MA,LY -blocking SYMINDP_MA_BF,STI_GOX,N_SOURCE_DRAIN,MA -blocking INDS_MA_M1,STI_GOX,N_SOURCE_DRAIN,MA,M1,M2,M3,M4 -blocking INDS_MA_BF,STI_GOX,N_SOURCE_DRAIN,MA -blocking INDP_MA_M1,STI_GOX,N_SOURCE_DRAIN,MA,M1,M2,M3,M4 -blocking INDP_MA_BF,STI_GOX,N_SOURCE_DRAIN,MA -blocking IND_MA_M1,STI_GOX,N_SOURCE_DRAIN,MA,M1,M2,M3,M4 -blocking IND_MA_BF,STI_GOX,N_SOURCE_DRAIN,MA -res_blocking ma_transmission,ma -blocking ma_transmission,STI_GOX,N_SOURCE_DRAIN,MA -res_blocking ESD_pdnw,pc_parasitic -res_blocking ESD_ndsx,pc_parasitic -blocking ESD_pdnw,STI_GOX,N_SOURCE_DRAIN,PC -blocking ESD_ndsx,STI_GOX,N_SOURCE_DRAIN,PC /home/eng/h/hxr150330/cad/cadence/LVS_RUN/xor2lvs
ERROR (LBRCXM-633): Bad return status from RCX script generator. Status 256
INFO (LBRCXM-709): *****  QRC terminated abnormally  *****
    Hard to know exactly what the problem is from this.
    However, is there a good reason why you're using a 6 year old version of QRC? My first suggestion would be to use something more recent. It's quite likely that whatever problem is causing an internal error is now either solved or is producing a clearer error message in a version produced more recently...
  • harinarain
    I don't know why is the university using this QRC yet. This is the only model we get to use and so the choice is limited. Also, this problem is only occuring on my machine and not on anyone else's machine. So I'm the only one stuck with this. any further help is highly appreciated.
    Do you have any clue why this error might occur ? I have tried all the techniques to solve this at my disposal.
    Hari
    If you're stuck, and it works on other machines, why not just use one of the other machines? As I said, it's highly likely it will need a software update - it's always possible there's a workaround, but without being able to see the data (and this would be better dealt with by somebody in customer support who deals with QRC far more regularly than me), I doubt there's much advice we can give from such a non-specific error.
