  3. Assura QRC Error
  • Views 18031
Assura QRC Error
sdineshkumar
sdineshkumar over 10 years ago
Hello Andrew
I am using Cadence Virtuoso IC 6.1.6, I am trying to do parasitic extraction for an inverter, which i designed using gpdk 45nm. However i am don't see QRC or RCX option in Assura menu. Below is the screenshot you can find. I would like to know how to solve this issue.
Thanks and Regards
Dinesh Kumar
    Dinesh,
    That's simple. You don't have the $QRC_HOME environment variable set. This needs to point to an extraction hierarchy - e.g. EXT152 or EXT151. You also need to have $QRC_HOME/bin in your UNIX path (e.g. $path in csh, or $PATH in general).
  • sdineshkumar
    Hello Andrew
    Thank you. It resolved the issue. Now i have a different issue while running Assura-Quantus QRC. The following is the error message.
    INFO (LBRCXU-108): Starting
    /usr/local/cadence/installs/ASSURA41/tools.lnx86/assura/bin/avRCXxref /home/dkse222/45nm/assura_rcx/inv/__qrc.rcx_cmd -useRunName
    @(#)$CDS: avRCXxref_64 version av4.1:Production:dfII6.1.6-64b:IC6.1.6-64b.101 08/06/2013 13:36 (sjfnl785) $
    sub-version 4.1_USR4, integ signature 2013-08-06-1301
    run on coe4491 at Mon May 2 17:48:04 2016
    Reading rsf
    INFO (LBRCXU-114): Finished /usr/local/cadence/installs/ASSURA41/tools.lnx86/assura/bin/avRCXxref
    INFO (LBRCXM-642): Constructing the RCX run script
    /usr/local/cadence/installs/EXT151/tools.lnx86/extraction/bin/64bit//capgen: error while loading shared libraries: libtermcap.so.2: cannot open shared object file: No such file or directory
    INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
    /usr/local/cadence/installs/EXT151/tools.lnx86/extraction/bin/64bit//capgen -techdir /usr/local/cadence/installs/IC616/tools.lnx86/gpdk045_v_4_0/qrc/best -lvs /home/dkse222/45nm/assura_rcx/inv.xcn -p2lvs /usr/local/cadence/installs/IC616/tools.lnx86/gpdk045_v_4_0/qrc/best/qrcTechFile -reseqn -p poly_conn,allGate,Oxide -canonical_res_caps -length_units meters -exclude_gate_res -cap_ground_layer psubstrate /home/dkse222/45nm/assura_rcx/inv
    Forking: /usr/local/cadence/installs/EXT151/tools.lnx86/extraction/bin/64bit//capgen -techdir /usr/local/cadence/installs/IC616/tools.lnx86/gpdk045_v_4_0/qrc/best -lvs /home/dkse222/45nm/assura_rcx/inv.xcn -p2lvs /usr/local/cadence/installs/IC616/tools.lnx86/gpdk045_v_4_0/qrc/best/qrcTechFile -reseqn -p poly_conn,allGate,Oxide -canonical_res_caps -length_units meters -exclude_gate_res -cap_ground_layer psubstrate /home/dkse222/45nm/assura_rcx/inv
    ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
    INFO (LBRCXM-709): ***** Quantus QRC terminated abnormally *****
    How can I solve this issue?
    QRC version
    Name : qrc - Quantus QRC - (64-bit)
    Description : Quantus QRC Extraction program
    Version : 15.1.1-s174
    Build Ref. No. : 174
    IR Build No. : 174
    Build Date : Tue Jul 7 21:42:47 PDT 2015
    ASSURA41 is the version i am using if that helps
    Thank you
    Dinesh Kumar
    It looks as if you don't have libtermcap.so.2 (the 64-bit version) installed on your machine. On my RHEL6 machine this is at /lib64 and comes from this RPM:
    compat-libtermcap-2.0.8-49.el6.x86_64
    On a RHEL5 machine, it came from this RPM:
    libtermcap-2.0.8-46.1
