  3. Pass Path and Filename via Variable in ADEXL
  • Views 16241
SebastianS
SebastianS over 10 years ago
Hi!
I'm using ADEXL and pass DC state files to a transient simulation. Up to here this concept works fine for me.
In the transient simulation I put VAR("readic") for readic, and then I want to give different files for different corners.
Definining a filename is no problem, e.g. "spectre.ic", however when I include a full unix path I get netlisting errors, e.g. "/path/spectre.ic". Netlisting error is gone when I remove the initial slash, but then he won't find the file. Is there any restriction that strings are not allowed to start with a slash? When I put the same content directly in the transient analysis readic box, it works well.
Anybody faced the same problem before?
Thanks, Sebastian
