  3. lineread command error out when trying to read a verilog...
  • Views 14985
lineread command error out when trying to read a verilog generation log file
mlea
mlea over 10 years ago
Im using lineread command to read in from an input port .
Im reading the verilog si log file m which contain line such as ( start with):
/p/virtuoso/blabla
and also:
*/sdf/bla
the command lineread error out with syntax error, maybe because it is intended to parse things more than read in complex list ( which is what the  line is)
i tried other commands as well : read , linereadstring.  also sprintf("" %L lineread(line)) doesnt help..
what can be done is such cases?
thx
meny
    Meny,
    Please don't post the same question in more than one forum. The guidelines ask you not to do this.
    This is the same as your other other post: http://community.cadence.com/cadence_technology_forums/f/48/t/35636
