  3. How to flatten layout cells and preserve pin names when...
  • Replies 10
  • Views 23628
How to flatten layout cells and preserve pin names when pin names from different cells are the same
twen
twen over 10 years ago
I am using virtuoso version 6.1.6-64b 12/07/2015 20:18 (sjfbm186) .
Suppose I have a top level cell T, and T contains two cells A and B, and there are a pin called P in both A and B. When I flatten cells A and B by gui (Preserve pins, preserve ROD Objects) to by foreach(s list(dbA dbB) dbFlattenInst(s 1 t t t t t t t)), the pin P in cell A is brought up into cell T without any problem. However, the label on pin P in cell B is renamed to something like dbNet032. I see this can be useful in certain cases, but it is not what I want.
Is there anyway that I can flatten A and B and brought up the pin P to cell T and keep both pins' label as it was?
Thanks in advance,
TJ
  • Quek
    Quek over 10 years ago
    Hi TJ
    After flattening 2 instances I1 and I2, you should have the following 2 pins at the top level:
    pinName : I1|pinP
    terminalName: pinP
    pinName : I2||pinP
    terminalName: dbNet1
    (IC617 will name it as "I2|pinP")
    The following warning will also be shown in CIW:
    *WARNING* (DB-270000): dbCreateTerm: Terminal with name 'pinP' already exists
    Suppose Virtuoso preserves the terminal name for inst2, we would have the following situation:
    pinName : I2||pinP
    terminalName: pinP
    In terms of pin connectivity model, this would mean that pins "I1|pinP" and "I2|pinP" are strongly connected under the terminal "pinP". By setting the terminal name as "dbNet1", the 2 pins would not be related to each other.
    If creating strongly connected pins is really what you need, you will have to use a SKILL script to post process the flattened results so that the terminal names are the same.
    Best regards
    Quek
  • Quek
    One correction:
    this would mean that pins "I1|pinP" and "I2|pinP" are weakly connected under the terminal "pinP"
    2 pins (each with 1 fig) under 1 terminal => weakly connected
    1 pin with 2 figs under 1 terminal => strongly connected
    Maybe this will help. I wrote this a long time ago - haven't tested it recently though.
    /* abFlattenInst.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jul 29, 1998
    Modified
    By
    Instance flattener which doesn't rename pins
    Can be used in place of dbFlattenInst() or leFlattenInst()
    The arguments are the same with the exception of the additional netSuffix argument,
    which can be ignored as it is optional.
    Ended up slightly more complex because of having to deal with the case
    that you can't dbMergeNet two nets which both have terminals
    SCCS Info: @(#) abFlattenInst.il 03/23/99.22:04:30 1.2
    (procedure (abFlattenInst inst levels @optional pcells? preservePins?
                              (netSuffix "_abFlatTmp"))
      (let (result termName oldNet newNet renamedNets cellView pinFigs)
           (if preservePins?
               (progn
                (setq cellView (dbGetq inst cellView))
                /* see if any of the terminal names on the instance match any
                   existing nets in the parent cellView; if so, rename them */
                (foreach term (dbGetq (dbGetq inst master) terminals)
                         (setq termName (dbGetq term name))
                         (when (setq oldNet (dbFindNetByName cellView termName))
                               (setq renamedNets (cons termName renamedNets))
                               /* rename the net */
                               (setq newNet (dbMakeNet cellView (strcat termName netSuffix)))
                               (dbMergeNet newNet oldNet)
                               /* rename the terminal, to stop it clashing too */
                               (when (dbGetq newNet term)
                                     (dbSetq (dbGetq newNet term) (strcat termName netSuffix) name))
                /* do the flattening */
                (setq result (dbFlattenInst inst levels pcells? preservePins?))
                /* any nets which were renamed have to be renamed back to the original name */
                (foreach netName renamedNets
                         (when (setq oldNet
                                     (dbFindNetByName cellView (strcat netName netSuffix)))
                               (setq newNet (dbMakeNet cellView netName))
                               /* get the figures which are the pins, and delete the "new"
                                  terminal */
                               (setq pinFigs (dbGetq (dbGetq (dbGetq newNet term) pins) fig))
                               (dbDeleteObject (dbGetq newNet term))
                               /* rename the terminal back again */
                                     (dbSetq (dbGetq newNet term) netName name))
                               /* go through the old pin figures and reattach them to the
                                  new net */
                               (foreach fig pinFigs
                                        (dbCreatePin newNet fig))
                result
               /* otherwise, if preservation of pins is off, just flatten as normal */
  • twen
    Hi, Quek,
    Thank you for explaining the complications of the issue.
    TJ
  • twen
    Hi, Andrew,
    Thank you for the code. I'll need to study your code and debug it in order to explain why it still renames the pins. Here is how I used your code after selecting 5 instances:
        foreach(sel geGetSelSet() abFlattenInst(sel 1 t t ""))
    *WARNING* (DB-270000): dbSetTermName: Terminal with name 'P' already exists
    *Error* dbDeleteObject: argument #1 should be a database object (type template = "d") - nil
    I'll post the detail once I found it out.
    TJ
    The problem is that you passed "" as the fifth argument to abFlattenInst. That will break the code completely, because it means that it tries to rename each net to the same name it is already - the whole point is that it temporarily renames the nets with a suffix (default called "_abFlatTmp") to avoid a clash, flattens, and then merges them back afterwards. The temporary name no longer exists at the end - so you should not have to specify this at all except in the unlikely event that you already have nets/terms with the suffix "_abFlatTmp".
    The comments at the top of the code also suggest you can ignore the suffix comment.
    By specifying the suffix as "", nothing gets renamed, and hence you end up with the clash still every time it tries to flatten.
    I ran:
    foreach(sel geGetSelSet() abFlattenInst(sel 1 t t))
    and that worked fine.
  • twen
    Oh, that explains part of the problem. The reason that I use "" as the suffix is try to avoid this problem without careful thinking.
    *WARNING* (DB-270000): dbMakeNet: Input name (or member): ov_out<79>_abFlatTmp has improper bus syntax
    So I changed your code to use it as prefix instead of as suffix and this warning went away.
    The only remaining issue is that the duplicated pins brought up are preserved as expected but their attached labels are deleted from all pins except those pins from the first flattened instance.
    TJ
    Ah, the perils of a program I wrote 18 years ago and obviously hadn't tested that much!
    I'll take a look tomorrow to update it to make sure it preserves the labels and textDisplays.
  • twen
    Hi, Andrew,
    I am impressed that the program your wrote 18 year ago is still working and is sort of working in my case!
    I am wondering if you could create a new version of dbFlattenInst() instead of wrapping around the existing dbFlattenInst() so you do not need to do the renaming and deleting, provided that the existing dbFlattenInst() is not thousands-line long and would not take you too long?
    TJ
    Hi TJ,
    dbFlattenInst is not implemented in SKILL (it's in C++) and so wrapping the existing flatten is the most pragmatic approach (there are other ways, but most of the problems would be similar anyway). So I can't just rewrite the existing dbFlattenInst. This would be a good enhancement for dbFlattenInst2, potentially (this is a new form with a few additional options, but it doesn't have this behaviour yet).
