  3. ASSURA lvs problem
  • Views 16156
ASSURA lvs problem
Hianna
Hianna over 10 years ago
Hello. My name is Anna.
I am a layout engineer.
I want to run lvs with ASSURA 410. but it couldn't work well.
The log file is attatched.
Please help me solve this problem.
Thanks.
            Assura (tm) Physical Verification Version av4.1:Production:dfII5.1.41:5.10.41.500.6.144
            Release 4.1_USR1_HF14
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av4.1:Production:dfII5.1.41:5.10.41.500.6.144 10/14/2010 06:37 (logavt05) $
sub-version 4.1_USR1_HF14, integ signature 2010-10-14-0644
run on hercules from /EDA/Cadence/ASSURA410/tools.lnx86/assura/bin/32bit/assura on Thu May 26 10:40:51 2016
Starting /EDA/Cadence/ASSURA410//tools/assura/bin/aveng /home/ky11201/RSC102V2/VER/ASSURA/lvs/ssh1219_Opamp_LDO_Heat_V1.rsf -exec1 -LVS -cdslib /home/ky11201/RSC102V2/cds.lib
@(#)$CDS: aveng version av4.1:Production:dfII5.1.41:5.10.41.500.6.144 10/14/2010 06:38 (logavt05) $
run on hercules from /EDA/Cadence/ASSURA410/tools.lnx86/assura/bin/32bit/aveng on Thu May 26 10:40:51 2016
 Summary Report: ssh1219_Opamp_LDO_Heat_V1.sum
 RSF           : /home/ky11201/RSC102V2/VER/ASSURA/lvs/ssh1219_Opamp_LDO_Heat_V1.rsf
 Library Name  : rsc102v2_prj
 CDSLIB Path   : "/home/ky11201/RSC102V2/cds.lib"
 Cell Name     : ssh1219_Opamp_LDO_Heat_V1
 View Name     : layout
 Rules File    : /home/ky11201/RSC102V2/Assura/lvsrcx/extract.rul
 Options       : -exec1 -LVS -cdslib /home/ky11201/RSC102V2/cds.lib
 Work Directory: /home/ky11201/RSC102V2/VER/ASSURA/lvs
 Operating Mode: Legacy Mode is Off
Starting dfIIToVdb...
@(#)$CDS: dfIIToVdb version av4.1:Production:dfII5.1.41:5.10.41.500.6.144 10/14/2010 06:40 (logavt05) $
run on hercules from /EDA/Cadence/ASSURA410/tools.lnx86/assura/bin/32bit/dfIIToVdb on Thu May 26 10:40:52 2016
*WARNING* Cannot find /EDA/Cadence/ASSURA410/tools.lnx86/dfII/etc/tools/layoutXL directory to load environment variables
*WARNING* envSetVal: could not find tool[.partition] 'layoutXL'
*WARNING* Cannot find /EDA/Cadence/ASSURA410/tools.lnx86/dfII/etc/tools/layout directory to load environment variables
*WARNING* envSetVal: could not find tool[.partition] 'layout'
Initializing cap.cbe from libInit.il for library tsmc25rf...
Initializing diode.cbe from libInit.il for library tsmc25rf...
Initializing mos.cbe from libInit.il for library tsmc25rf...
Initializing jv.cbe from libInit.il for library tsmc25rf...
Initializing vpnp.cbe from libInit.il for library tsmc25rf...
Initializing rfres.cbe from libInit.il for library tsmc25rf...
Initializing ind.cbe from libInit.il for library tsmc25rf...
Initializing resnwod.cbe from libInit.il for library tsmc25rf...
Initializing cap_mos.cbe from libInit.il for library tsmc25rf...
Initializing mos5.cbe from libInit.il for library tsmc25rf...
Initializing vpnp5v.cbe from libInit.il for library tsmc25rf...
Initializing mvarcap.cbe from libInit.il for library tsmc25rf...
Initializing res.cbe from libInit.il for library tsmc25rf...
Initializing rphripoly.cbe from libInit.il for library tsmc25rf...
Initializing rfmos.cbe from libInit.il for library tsmc25rf...
Initializing npn.cbe from libInit.il for library tsmc25rf...
Initializing metRes.cbe from libInit.il for library tsmc25rf...
Initializing ind.ile from libInit.il for library tsmc25rf...
Initializing utility.ile from libInit.il for library tsmc25rf...
Initializing res.ile from libInit.il for library tsmc25rf...
Initializing tsmcUtilities.ile from libInit.il for library tsmc25rf...
Initializing tsmc25rfMosUpdate.ile from libInit.il for library tsmc25rf...
Initializing netlist.ile from libInit.il for library tsmc25rf...
function tsmcCdlSubcktCall redefined
Initializing mos.ile from libInit.il for library tsmc25rf...
Initializing addWire.ile from libInit.il for library tsmc25rf...
Initializing lo2rfupdateLib.ile from libInit.il for library tsmc25rf...
Initializing updateCDFs.ile from libInit.il for library tsmc25rf...
Initializing jv.ile from libInit.il for library tsmc25rf...
Initializing cap_mos.ile from libInit.il for library tsmc25rf...
Initializing rfmos_w10.ile from libInit.il for library tsmc25rf...
Initializing tsmc25rf_updateCDFs.ile from libInit.il for library tsmc25rf...
function tsmc25rf_updateCDFs redefined
Initializing mpp.ile from libInit.il for library tsmc25rf...
Initializing resnwod.ile from libInit.il for library tsmc25rf...
Initializing metRes.ile from libInit.il for library tsmc25rf...
Initializing varcap.ile from libInit.il for library tsmc25rf...
Compiling rules...
WARNING LVS Run detected.
Non-legacy mode has been disabled for this LVS run
Checking out license for Assura_LVS 4.10
Reading the design data...
Finished dfIIToVdb.
Building the VDB part 2 in background mode.
Building tables for LVS Preprocessing in background mode.
Starting /EDA/Cadence/ASSURA410/tools/assura/bin/vdbToCells /home/ky11201/RSC102V2/VER/ASSURA/lvs ssh1219_Opamp_LDO_Heat_V1
Finished /EDA/Cadence/ASSURA410/tools/assura/bin/vdbToCells
Starting Nvn PreExtraction...
Starting /EDA/Cadence/ASSURA410/tools/assura/bin/nvn /home/ky11201/RSC102V2/VER/ASSURA/lvs/ssh1219_Opamp_LDO_Heat_V1.rsf -preExtract -exec1 -cdslib /home/ky11201/RSC102V2/cds.lib
@(#)$CDS: nvn version av4.1:Production:dfII5.1.41:5.10.41.500.6.144 10/14/2010 06:41 (logavt05) $
run on hercules at Thu May 26 10:40:53 2016
 WARNING (AVLVSNN-10029) : 'filter' command has been converted into 'filterOptions' with the same function. 'filter' command is not supported. Use 'filterOptions' instead.
Reading schematic network
.SUBCKT spiral_turn TOP BOTTOM
SYNTAX ERROR found at line 8 column 2 of file  /home/ky11201/RSC102V2/VER/ASSURA/lvs/ssh1219_Opamp_LDO_Heat_V1.vlr
*Error* lineread/read: syntax error encountered in input
*Error* load: error while loading file - " /home/ky11201/RSC102V2/VER/ASSURA/lvs/ssh1219_Opamp_LDO_Heat_V1.vlr "
*Error* load: error while loading file - "*loadstring*"
Error - Problems in dfIIToVldb rules file /home/ky11201/RSC102V2/VER/ASSURA/lvs/ssh1219_Opamp_LDO_Heat_V1.vlr. Terminating
*WARNING* /EDA/Cadence/ASSURA410/tools/assura/bin/nvn exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
Finished /EDA/Cadence/ASSURA410/tools/assura/bin/nvn
*WARNING* An error occurred during Nvn PreExtraction.
LVS preprocessing requires a successful run of Nvn.
Assura will now terminate.
*WARNING* Bad exit from child process .. 0x100
*****  aveng terminated abnormally  *****
*****  aveng fork terminated abnormally  *****
*WARNING* aveng exit with bad status
    It's very hard to tell from the log file precisely what you've done wrong, but it looks as if you've managed to pass a netlist to something that is expecting a VLR file - it looks like something in CDL/SPICE syntax but it's not expecting that.
    I'd say we'd need to see your Assura input setup - it might just be simpler to go to customer support so an application engineer can take a look at your files.
  • Mehdi Nasr
    Mehdi Nasr over 10 years ago
    When I run LVS, the Cadence gives me the error " the schematic 'Res' is unbound to any layout device". I have checked EDABOARD and your suggestions here. But I could not figured it out. I have checked all the connections and all the layers but still I have the same error. What is your suggestion?
    Mehdi
