  3. Import Spice generated by Tempus
  • Views 17182
zaratustra
zaratustra over 10 years ago
Before asking my questions, here follows the software versions that I'm using:
virtuoso -W:  IC6.1.6-64b.500.11
spectre - W: 13.1.1.049
tempus and voltus - W: 15.14-s048_1
This is the flow I'm using:
1) I simulated a circuit using Voltus to obtain IR-DROP profiles (OK)
2) I imported the IR-DROP profiles into Tempus (OK)
3) I exported the critical path of the circuit from Tempus to spice (with the IR-DROP profiles - Command:    create_spice_deck ...).
4) I imported the generated spice by tempus into Virtuoso using SpiceIn.
 4.1) First problem: the generated spice uses "/" and when importing into Virtuoso it stops at the first "/", so I removed all slashes "/" from the spice. It worked, however, I would like to know if this is expected or if there's another solution?
E.g.:
XStage1 U3_INST_next_reg_24_/CP U3_INST_next_reg_24_/Q U4088/A Stage1
to
XStage1 U3_INST_next_reg_24_CP U3_INST_next_reg_24_Q U4088A Stage1
4.2) The importation worked fine without the "/" and now I have the schematics.
4.3) When I try to simulate using spectre, it complains: "ERROR (CMI-2198) Waveform is not defined in V5..." also in V10...
 Analyzing these Vsources, I understood the problem, however, I still don't know the solution.
 Problem: In spice, the IR-drops were defined as a PWL: "V1 U3_INST_next_reg_24_CP 0 PWL(+ 9.99999971718e-10        0
+ 1.0049999717e-09         0.71473...)
Those PWL were translated as a "wave" parameter which doesn't exist in Vsource (analogLib), therefore the values aren't being read. I can copy manually the values to the correct parameters from Vsource (t1, v1, t2, v2...), however, I have so many voltage sources and so many circuits that it would take too long. Anyone know if is there another solution?
Thank you in advance,
Raphael
    I've not tried importing a netlist with a PWL source like this - it may just be a limitation of the SPICE import which you'd have to report to customer support to get improved.
    However, why are you importing this into virtuoso anyway - seems a bit of an odd thing to do. Wouldn't it be simpler just to run spectre on the netlist from the command line? I can't see any significant benefit in importing it...
  • zaratustra
    Hello Andrew,
    Thank you for your answer.
    You are saying to use: "spectrespp mycircuit.sp"? If yes, is it possible to run from Ocean script? Because I would use a simulation environment that I've created to simulate transient faults.
    I've also tried to simulate spice by creating a cell view (spice) and then copying the netlist, however, the symbol for this view is not created (I suppose it's because I have 32 subckts at the same level in the same netlist). Anyway, reading the Spectre manual I discovery this "spectrespp". Is this the direction you are suggesting?
    Raphael
    No. spectrespp is an ancient program which stopped being shipped after MMSIM61 (so in about 2005). Similarly the old "spp" pre-processor stopped being shipped after MMSIM11.1 (about 2011). Using a pre-processor to translate SPICE to spectre syntax has really been unnecessary since at least 2004 as spectre's native support for SPICE syntax was completely overhauled and is very comprehensive now.
    So you can directly run spectre on a SPICE netlist nowadays. Of course, this depends on whether your netlist has any analysis statements in (I'm not really that familiar with Tempus, so I'm not sure what it spits out). If it's just a netlist with components and sources, but no analysis statements, you could either create that by hand, or use OCEAN to include the netlist. One way to do that is to do:
    design("/path/to/netlist/netlist")
    I'd generally suggest putting everything in a directory called "netlist", having the main netlist called "netlist" and then creating two empty files called netlistHeader and netlistFooter in the same directory - this keeps everything happy. Then you could just add your analysis statements in your OCEAN script as usual, run the simulation from OCEAN, and do the post-processing there.
  • zaratustra
    Thank you Andrew. Your explanation was very straightforward. Now it's more clear what and how to do.
    Raphael
