  3. Nesting commands in Virtuoso Layout Suite L User Guide
  • Views 16321
BaaB
BaaB over 10 years ago
This is a description about nesting commands in Virtuoso Layout Suite L User Guide:
You can pause before completing one command to perform a second command. This is called nesting a command. For example, if you move an object and then zoom out, the zoom command would be nested, allowing you to use another command such as moving another object.
I don't understand how it works. Could you explain more? In this case, we are moving an object then zoom out and the zoom command is nested.
How can I move another object without escape the current command? I tried the example above but I couldn't move another object as the description.
What does it mean to set the nest limit to 2 or 3?
Thank you.
    The principle behind nesting is that you can start one command, then when in the middle of that command, start another, then start another and so on; as you finish each command it pops back out to complete the previous command.
    Mostly this is used to allow you to do things like start an editing command (like copy, move, stretch etc) and then do a zoom whilst within that. For example, I could start move, then hit z to zoom and before I zoom I hit Tab to do a Pan (or pick the menu). I finish the pan by clicking on a new location, then I am prompted to finish the zoom, and then it goes back to the move.
    Some of the flexibility has been removed in order to get better consistency and to reduce confusion. Some of the editing commands reset the nesting stack - so when you start a copy or a move, it effectively starts the stack from scratch again - so any commands you were doing before are replaced by the new command. In the past in older versions, you used to be able to get in a bit of a mess with the nest stack and sometimes the stack wouldn't get reset so after some time you'd have to increase the nesting stack to get the tools to behave properly. I've not seen that problem for years though.
    So I'd say nowadays there's really no need to touch the nest limit (in Options->User Preferences in the CIW) because the default is pretty much always sufficient.
  • BaaB
    Thanks a lot. I realized that I used it a lot before with move and zoom in commands but I didn't  know what was it called.
    Another question, it may sound stupid but could you explain what is Pan? I tried to consult it in dictionary and tried the command but couldn't see how it is useful.
    Thank you.
