  3. Definition of all layers in LSW - Layout Suite XL Editi...
  • Views 9486
Definition of all layers in LSW - Layout Suite XL Editing
BaaB
BaaB over 10 years ago
Could you tell me where could I find the definition of all layers in LSW for a specific process?
I think it is hidden somewhere in the simulator. I couldn't find a definition of a particular layer by Google.
Thank you.
  • Sattar72
    Sattar72 over 10 years ago
    Hi, Your question is unclear. You want definition, purpose of each layer in layout view then you have to go through technology file on which process you are working.
  • BaaB
    Thank you.
    I would like to know at least what is the name of each layer, for example, "OD drw" means Oxide Diffusion.
    If there are other information about each layer, that would be great.
    Could you tell me where could I find the technology file?
  • Sattar72
    Which Process node are you working. It will be available in Current Working directory just like techfile.tf. It Consists of ......... functions(
    ;( layer function [maskNumber])
    ( Nburied "recognition" 1 )
    ( Nwell "nwell" 2 )
    ( Pwell "pwell" 3 )
    ( Poly "poly" 4 )
    ( Oxide "diff" 5 )
    ( Nimp "nplus" 6 )
    ( Pimp "pplus" 7 )
    ( Cont "cut" 8 )
    ( Metal1 "metal" 9 )
    ( Via1 "cut" 10 )
    ( Metal2 "metal" 11 )
    ( Via2 "cut" 12 )
    ( Metal3 "metal" 13 )
    ( Via3 "cut" 14 )
    ( Metal4 "metal" 15 )
    ( Via4 "cut" 16 )
    ( Metal5 "metal" 17 )
    ( Via5 "cut" 18 )
    ( Metal6 "metal" 19 )
    ( OVERLAP "passivationCut" 20 )
    The original question is a little odd - I can't see why you would think that it's "hidden in the simulator". The simulator doesn't care less about the layers used for layout.
    Also, the chances are the technology file is not in the working directory - so the response above isn't correct either.
    Most likely you're working with a particular PDK (Process Design Kit). That PDK will have a technology library, which is what is defining all the layers used and usually the devices that you use for both simulation and layout. The technology file will be a binary database associated with the technology library (most likely) - and it's this library you either "reference" or "attach" to when creating a new design library.
    You can get a text representation of the technology file by using Tools->Technology File Manager in the CIW, and then using the "Dump" button on the form. Pick the appropriate library, specify a filename, and then turn all the sections on that you wish to dump (start with dumping them all). You can then look for the functions section in the layerRules block. This will give you the function of each layer - at least at a high level. Exactly what the layers are called is specific to the technology - it depends on the conventions used by that company. The best thing would be to read the documentation associated with the PDK, as the chances are it will explain the meaning of each layer in more detail.
    You may also want to talk to your University supervisor to understand some more about IC technology and EDA tools - it sounds as if you could do with a bit more insight into how things work in practice.
    Kind Regards,
  • BaaB
    Well, very comprehensive!
    Thank you very much! It means a lot to me.
    I have just tried that and it seems that almost necessary infor is there.
