  3. Simulation Log does not update (ADE L)
  • Views 15164
nbyrne
nbyrne over 10 years ago
Every time I run a simulation my simulation log comes up with the output from the last simulation, and doesn't auto-update while the simulation is running.
DFii version: IC6.1.7-64b.78
virtuoso -W: sub-version  IC6.1.7-64b.78
spectre -W: sub-version  14.1.0.627.isr8
Niall.
    Niall,
    This sounds odd. I don't think I've seen this - can you contact customer support? We probably need to take a look at your environment (maybe there's a wrapper in your environment that's messing something up - not sure).
  • nbyrne
    Will do, thanks Andrew..
