  3. How to create "extracted netlist file"
  • Views 5819
fatcat1206
fatcat1206 over 10 years ago
Hi All
I am trying to update the binding in the layout view with LVS results, in order to make the view Layout-XL compliant.
When reading the Cadence document, 2 files (.ixf and .net files) are needed as mentioned below.
"Note: PVS creates a .ixf cross-reference file in the svdb directory of the PVS run directory when using the PVS Create QRC Input Data option.
Note: PVS creates a .net extracted netlist file in the svdb directory of the PVS run directory when using the PVS Create QRC Input Data option."
For the .ixf file, it has been generated when I run the LVS and enable the “Create Quantus QRC Input Data”
But there is no .net file as mentioned by the document.
On the other hand, it has also been mentioned in the document
"If you run PVS in LVS mode with the -qrc_data argument specified, the extracted netlist gets created in the form of a .spi file in the same directory as the .ixf. The .spi file provides a normalized output for QRC and may not be useful for generating the binding file required by Update Binding. Therefore, you must ensure that you set lvs_keep_data to yes in your lvs.pvl rule file so that the extracted netlist output file is a .net file, which can be read by the Update Binding form."
But I did not find the “lvs_keep_data” in the lvs.pvl file.
Does any one have a clue how to get the "extracted netlist file", or has a work around to update the binding according to the LVS results.
Best Regards
Yi
    Hi Yi,
    Good to see you on Monday - sorry for not responding soon - the tour continued!
    Anyway, what you have to do is create a text file (e.g. "extra.pvl") and put in this file:
    lvs_keep_data yes
    Then on the Rules page of the PVS LVS form, add this extra file as an additional rules file.
    I did this, and together with the generate QRC data, I got both the .ixf and .net file, and was able to use those for Update Bindings (I put together a small example on the plane home tonight, and it worked a treat).
  • fatcat1206
    Hi Andrew
    It's also my pleasure to see you on Monday.
    The presentation is great, and the new features from 6.1.7 are really useful.
    I will try them out, and it would help a lot in the coming works.
    The method for extra .pvl file works, the .net file has been generated.
    I am trying out the binding flow in a layout of charge pump, where metal-to-metal cap and mosaics are used.
    This would be quite challenge. I will read more document about it.
    Best Regards
    Yi
