  3. Why transconductance gm exported from DC operating point...
  • Views 4824
Why transconductance gm exported from DC operating point is not same as dids/dvgs?
BaaB
BaaB over 10 years ago
Could anyone one explain why transconductance gm exported from DC operating point is not same as dids/dvgs?
I tried to simulate the circuit below and plot gm in two ways.
The first one is use gm operating point and the second is to take derivative, dids/dvgs and the results are not the same.
(I am using Cadence Spectre  Version 13.1.1.049 64bit and MMSIM131)
    Your test bench is varying Vds at the same time as Vgs, so the current is dependent upon Vds changing as well as Vgs. So taking the derivative (particularly at higher Vds) is not going to only give gm. gm is defined as the partial derivative of the current with respect to Vgs.
    If I use this test bench instead:
    // comparing gm with derivative of id wrt vgs.
    model nch bsim4 type=n
    M1 (d g 0 0) nch w=2u l=0.5u
    Vg (g 0) vsource dc=2
    Vd (d 0) vsource dc=5
    dc dc dev=Vg start=0 stop=5 step=0.01
    save M1:d M1:gm
    (I chose a fine step for the dc sweep to minimise the difference due to the step in the derivative), the I get:
    which as you can see is very close. I'm just using a fixed Vds in this case to avoid that having an influence on the current that's being measured.
  • BaaB
    Yeah, thank you very much for the answer. It took me a long time to figure that out.
