  3. test ordering in ocean-xl
  • Views 14471
danmc91
danmc91 over 10 years ago
In ADE-XL when I use calcVal in one test to refer to results from another test the simulation ordering seems to be right without me doing anything special.  Either that or I have just been luck.
I have just started to try switching over to Ocean-XL (because it is easier to re-use the moderately large amount of test setup on multiple similar designs) and I don't seem to be getting the correct orders.  My sweep simulation seems to be running *before* my calibration simulation which of course makes the results look bad (they are uncalibrated).
My sweep test has:
desVar(      "TRIM_CODE" "calcVal(\"Calibrated_TRIM_CODE\", \"calibration_test\")"    )
I generated the ocean-XL code from ADE-XL.  I'm using 6.1.6.500.14
Do I need to specify an order somewhere?  Also if I need to specify an order, do I also need to specify a depencency?  I have several tests and there are some dependencies as I've tried to indicate below (in Makefile syntax)
sweep_test: calibration_test
sweep_test2: calibration_test
sweep_test3:
sweep_testB: calibration_testB
It would be helpful to have a "big picture" document for ocean-xl showing the relation between things like sessions, setupDB, tests, history, etc.
A related question is if I have multiple sweep variables like:
ocnxlSweepVar("VDD" "{Inclusion List}3.0 3.3 3.6{Inclusion List}")
ocnxlSweepVar("sweep_temperature" "{From/To}Linear:-40:10:130{From/To}")
how do I tell ADE-XL and Ocean-XL which of these variables should be the x-axis on plots and which should be a new waveform?  For example, do I plot OUT vs sweep_temperature, one curve per VDD value or do I plot OUT vs VDD, one curve per temperature?  This gets worse if I'm doing this over process corners and the corners have a variable.    Maybe it has to do with which ocnxlSweepVar is listed first?  Maybe it has to do with which variable has more points?  Or maybe alphabetical?
-Dan
