  3. Power Supply Rejection (PSRR) on two phased auto-zero c...
  • Views 16725
Power Supply Rejection (PSRR) on two phased auto-zero comparator
Johanny Saenz
Johanny Saenz over 10 years ago
Hi all.
How could I performe a PSRR analysis of a two-phased auto zero comparator?
Could PAC help me on this case?
    Probably using PSS over the clock period of the comparator, and then PXF pointing at the output of the circuit - and then in the direct plot form for PXF you can click on your supply source - it would then tell you the transfer function from the supply to the output.
    Depending on what you need, you might need to look at sampled PXF - if so, there's an app note in <MMSIMinstDir>/tools/spectre/examples/SpectreRF_workshop (PSRR_Drv_AN.pdf) which talks about doing this on a divider to find the transfer function sampled at the point where the output of the divider changes (so effectively to look at how a signal on the supply affects the phase of the divider).
