  3. Monte Carlo Noise simulation using MDL
  • Subscribers 133
  • Views 15457
svcher
svcher over 10 years ago
Is there a way to run MC noise simulation using MDL?  I tried simple test code below, but it does not work:
mcnoise.mdl
alias measurement noise_test {
  run noise(freq=1e3,oprobe=v)
  export real total_noise=noise:out;
run montecarlo(numruns=100,variations='process,scalarfile="scalars") {
  run noise_test();
I used the above MDL file with the following Spectre netlist like this:
  > spectre =mdl mcnoise.mdl mcnoise.scs
mcnoise.scs
// Single resistor thermal noise, nominal value 12.8 pV/rtHz
op options rawfmt=psfascii temp=25
r (1 0) resistor r=100*(1+max(-0.99,dr))
v (1 0) vsource dc=1 mag=1
parameters dr=0
statistics {
  process {
    vary dr dist=gauss std=0.01
    Change the export statement to:
    export real total_noise=noise_test:out;
    The key is that I could see when running it that it names the noise analysis within the monte carlo:
    Noise Analysis `noise_test_noise_test': freq = 1 kHz
    It appears to work if I use noise_test:out instead.
  • svcher
    That was it. Thank you Andrew.
