  3. How to Manage External Netlist Files
  • Views 18220
twen
twen over 10 years ago
I am able to simulate with external Spice netlist with similar approach in "How to Simulate a Subcircuit (Netlist) With Spectre in ADE"  what I did is to set the model to the full path name of the simulated netlist file in the newly created symbol view and this work fine.I can also create a separate text or spice view like "myspice", "mydspf" to hold the netlist files and let the design manager to checkin the netlist file. This requires me to create one symbol view like "mysymbolview" and another spice view like "myspiceview." I am trying to combine these two views into a single one. I now have two new questions:
(1) Can I set the value of the component parameter "model" to a skill function that returns the concatenation of the absolute full path name of this symbol view and a file name like this "fullpathto/mylibpath/mycell/mysymbolview/spice.spi?" The benefit of this is that we do not need to update the hard coded full path name once this cell is copied to another library.
(2) Can I let the third party library design manager to check in "mylibpath/mycell/mysymbolview/spice.spi" to mysymbolview.I tried putting a data.reg in my home directory:
+DataFormat schematicSymbol {
    Co_Managed = master.tag thumbnail_128x128.png symbol.oa spice.spi;
and the design manager does not seem to pay attention to this registration file after I restarted Virtuoso. I am new to how the data manager works by the way. If you can confirm that (2) can only be done by the third party design manager, I can ask our tool support engineer to relay this question to the library design manager vendor.
Any help to solve the above two questions is greatly appreciated.
getVersion
"@(#)$CDS: virtuoso version 6.1.6-64b 12/07/2015 20:18 (sjfbm186) $"
TJ
    It sounds as if you really want the proper spice view or spectre text view support. Please contact customer support about this, because we need to know that you need this rather than providing cumbersome workarounds...
    I'm reluctant to give you workarounds that will involve some messy SKILL code to include the file during simulation. Note that you don't have to make the filename a full path in ADE - you can give a local path and then use Setup->Simulation files and set the include path (and this can be relative to the working directory, e.g. "./mylib" ).
    The data.reg approach you're taking ought to work, but it depends on which DM tool you're using - which tool is it?
    That said, I think the "right" way to do this is ultimately to have two views - the symbol and then a SPICE/spectre text view which you can switch into using the view list or hierarchy editor.
  • twen
    Hi, Andrew,
    Thank you for the response on Sunday! I just created case 46006238 for the netlister to natively support the spectre/spice/dspf textual views.
    We are currently using Cliosoft and I could not make it automatically check in the spice file inside the "shadow" symbol view directory. I won't spend time trying to make this work as it only simplifies things.
    Before the nestlister natively supports spice/spectre/dspf text views, I am still interested in a skill or other functions that I can put in the value field of an view's CDF/cell view property that returns the path name of the view so that I do not need to manually modify it after I copy this view to another library or rename it.
    Tingjun
    Tingjun,
    This is beyond what I'd like to cover in a discussion on the forums. There are some potential workarounds (I have some code) but you should follow this up via the case. The AE dealing with it can always get in contact with me for the SKILL code I have which might help (it wouldn't update the value field, but instead it would add the path in at the time of netlisting).
