  3. spectre simulation in batch mode with an include spectre...
  • Subscribers 133
  • Views 22102
spectre simulation in batch mode with an include spectre-netlist into an input.scs file
samung
samung over 10 years ago
I am generating a spectre-netlist file with an ocean batch commandline. This seems to work well.
Then, I try to include this file into an input.scs which gathers models, stimuli, analysis options, measures and ... an include line to this spectre-netlist file.
I have managed in making a spectre simulation of this input.scs, including the content of the spectre-netlist file.
However, my goal is to point to this spectre-netlist file, with something like: include <pathToTheFile>, into the input.scs
Is that possible ? What would be the syntaxe ?
  • input.scs content extract:
** parameters section
simulator lang=spectre
parameters I0=10000e-06
parameters nbcols=32
parameters vdd=10
** models section
* variables
parameters param1=1
parameters param2=0
* models
include "/home/.../model_corners.scs"
include "/home/model2_corners.scs" section=TC_TR
** netlist section
include "/home/.../cell.schematic.spectre.netlist"
  • cell.schematic.spectre.netlist extract:
subckt bc1m1t_lvt_sh bl sl vpw wl
parameters w1=0.12u
Mnsel (vd wl sl vpw) nlvtlp w=wsel*10e5 l=0.04 nfing=1 mult=1 srcefirst=1 \
mismatch=1 lpe=0 numcos=1 numcod=1 ngcon=1
Im (vd bl state) _mt radius=20e-08 initstate=0 nsmis=0 \
opMode=3
ends bc1m1t_lvt_sh
R1\<0\> (sli\<0\> gslo\<0\>) rm1 w=0.29 l=0.07
R3\<0\> (sli\<0\> lslo\<0\>) rm1 w=0.11 l=0.07
Ibc1614 (bli\<14\> sli\<0\> vss wli\<16\>) bc1m1t_lvt_sh wsel=0.30u
  • spectre.log:
Error found by spectre during circuit read-in.
ERROR (SFE-1802): "/home/.../cell.schematic.spectre.netlist" 5: Spectre "subckt" statements are not supported in spice language sections. Use "simulator lang = spectre" to introduce Spectre language sections.
ERROR (SFE-1802): "/home/.../cell.schematic.spectre.netlist" 6: Spectre "parameters" statements are not supported in spice language sections. Use "simulator lang = spectre" to introduce Spectre language sections.
ERROR (SFE-1025): "/home/.../cell.schematic.spectre.netlist" 118: Instance `Ibc1614': Unexpected value `wli<16>' - all required positional parameters have already been specified.
  • spectre cmdline:
spectre /home/.../input.scs +log /home/.../spectre.log
  • ocean cmdline:
ocean -nograph < /home/.../genNetlist.ocn > /home/.../ocean.log
  • genNetlist.ocn:
load(".cdsinit")
envSetVal("asimenv.startup" "projectDir" `string "/home/...")
simulator('spectre)
design("<library>" "cell" "schematic")
createNetlist(?recreateAll t ?display nil)
exit()
  • ocean .log:
WARNING (ADE-6001): The number of terminals specified in CDF termOrder are more
than the actual number of terminals in the cellview cell-view "cmos040lp_memprimitive" "bc1m1t_lvt_sh" "schematic"
WARNING (ADE-6004): Mismatch was found between the terminals in the cellView and those on the
termOrder property on the CDF. Because of the mismatch, the CDF termOrder will
be ignored. The terminals in the cellView will be netlisted in the alphabetical
order of their names. Eliminate the mismatch if you want the CDF termOrder
property to be used for netlisting.
Errors: 0 Warnings: 2
...successful.
compose simulator input file...
Loading devCheck.cxt
...successful.
As said above, if I copy paste the content of the spectre-netlist file into the input.scs, the spectre simulation ends successfully !!
Many thanks for your help,
P.
    This is simple to resolve. Spectre makes the assumption that if a file ends in the suffix ".scs" it is in spectre syntax, otherwise it's in SPICE syntax. So your file with the suffix ".netlist"  (cell.schematic.spectre.netlist) is treated as SPICE syntax when it's actually spectre syntax.
    There are two alternatives:
    1. Rename the file to be cell.schematic.spectre.netlist.scs
    2. Add the line "simulator lang=spectre" at the top of the cell.schematic.spectre.netlist file to change the language mode
  • samung
    thanks Andrew, the addition of the line: "simulator lang=spectre" suits well for my case.
