  3. spectre input.cs : conditional equation in .measure (min...
  • Views 15413
spectre input.cs : conditional equation in .measure (min of 2 measurements)
samung
samung over 10 years ago
using spectre in batch mode, I am trying to define the following conditional equation, to measure a capacitance.
I would like to know how to get the minimum between two parameters: maxvbl and V0 in my case, using the .measure strategy ?
input.scs extract:
parameters I0=10e-06
parameters V0=1.0
save blo\<16\> gslo\<0\>
.measure tran maxvbl max v(blo\<16\>)
.measure tran trigger param= 'min(maxvbl:V0)' <- conditional equation
.measure tran meas_when_trigger when v(blo\<16\>)='trigger'
.measure tran dvbl deriv v(blo\<16\>) at='meas_when_trigger'
.measure tran cbl param='I0/dvbl'
I cannot use spectremdl or ocean, using .measure syntaxe is somewhat mandatory to solve this point.
Thanks a lot in anticipation for any help,
P.
    I don't really understand why you can't use SpectreMDL for this, but the key problem is in your trigger calculation. You've used ":" instead of ",".
    parameters I0=10e-6
    parameters V0=1.0
    Vn (s1 0) vsource type=sine freq=1M ampl=1.1
    tran tran stop=2u
    simulator lang=spice
    .measure tran maxvbl max v(s1)
    .measure tran trigger PARAM='min(V0,maxvbl)'
    .measure meas_when_trigger when v(s1)=trigger
    .measure tran dvbl deriv v(s1) at=meas_when_trigger
    For me with a ":" it gave a very clear error. With the above example I get:
    Measurement Name : transient1
    Analysis Type : tran
    cbl = 2.75439e-12
    dvbl = 3.63057e+06
    maxvbl = 1.09687
    meas_when_trigger = 1.81692e-07
    trigger = 1
    I can change V0 to 1.2 (say) and it still works (then the measurement is taken at the peak of s1).
  • samung
    samung over 9 years ago
    Thanks Andrew, your suggestion ( ":" -> ",") works well !!
