  3. ADEXL results list ordering
  • Views 17316
PNadeau
PNadeau over 10 years ago
Small annoyance, but is there a way to set and remember the ordering for the results in the "Results" tab in ADEXL? (IC 6.1.7-64b.78, RHEL 6)
I can use the column headings to set them alphabetical (say by output name), but every time I leave the tab and come back, the results are reset to a random-looking order (this order seems to match the "per-test evaluation order" of the "Outputs Setup" tab).
Alternatively, can I change the "per-test evaluation order" of the "Outputs Setup" to achieve what I want?  If I click the yellow arrow labelled "reset table to display per-test evaluation order" I get access to the two blue arrows for moving results up and down the table, but these don't seem to work for me.  Click and drag also doesn't seem to work -- I get a blue line showing the destination, but the output doesn't actually move when I let go of the mouse button.
Phil
    Hi Phil,
    For me, changing the outputs order (either with the arrows or with drag and drop) works fine (in the version you're using and also in IC617 ISR5). Note that you can only change the order within the same test - you can't drag the order to be outside of the range of the named test - maybe that's the issue?
    I also see the sort order resetting when you switch tabs. There was a CCR a while back for a similar thing with detail transpose view - which has been fixed and works now - but I couldn't find one for normal "Detail" view.
    So you might want to contact customer support and request this be fixed.
  • PNadeau
    Dear Andrew,
    Thanks for the reply. Yes, I am trying within a test.  Given that yours is working, I checked more closely and it seems reordering in the "Outputs Setup" tab works in some but not all of my ADEXL sessions.  I cannot seem to find what is different about the ones that do not work (I am not sure how to debug -- there are no messages in CIW).
    And thanks for noting the "results" tab order resetting.
    Follow up with support is probably the best option for these.
    Thanks!
    Phil
