  3. Cadence Virtuoso Memory Limitation Issue
  • Views 21420
jdp721
jdp721 over 10 years ago
After completing a transient simulation (that generates ~ 2-3GB of psf files) in Virtuoso ADE-L, when the data tends to load in the ViVa display window, a dialog pops up (please see attached scrrenshot) indicating some kind of dearth in memory.
This doesn't always occur, but at times - and if this dialog comes, the data doesn't load (ViVa window remains blank) or partially loads.
Can you please indicate which memory does this refer to, and any setting in Virtuoso that can be tweaked to resolve this?
Thanks.
    You didn't say which version of Virtuoso you're using. It looks as if it's IC616 or before though, in which case the simplest solution is to run Virtuoso in 64-bit mode. This can be achieved either by:
    virtuoso -64
    or:
    setenv CDS_AUTO_64BIT ALL # (ALL may not be what you want, so check the documentation for this env var)
    virtuoso
    By default virtuoso runs in 32-bit mode in these versions which means your memory limits are about 4Gbytes (a bit less). In IC617 there is only 64-bit virtuoso available, so there's no need to do this. Historically we supported both 32-bit and 64-bit versions because a) sometimes people were running on 32-bit OS (although those haven't been supported for years, so that's no longer a reason) and b) there is a small performance penalty - it's pretty small - for running in 64-bit because of the increased memory access (any pointers double in size, so you consume more memory). However, those reasons weren't really worth the pain of running out of memory too often, so that's one of the contributing reasons why we only have 64-bit virtuoso from IC617 onwards.
  • jdp721
    Indeed I am using IC615.
    Thank you Andrew :)
