  3. Basic Libraries Not Showing up
  • Views 25276
David0618
David0618 over 10 years ago
Dear Community,
I just started trying out Cadence Virtuoso. I am having trouble including basic libraries like AnalogLib - please see screenshot below:
How would I go about adding the libraries?
Thanks.
    Add these lines into your cds.lib :
    DEFINE analogLib $(inst_root_with:tools/dfII/bin/virtuoso)/tools/dfII/etc/cdslib/artist/analogLib
    DEFINE basic $(inst_root_with:tools/dfII/bin/virtuoso)/tools/dfII/etc/cdslib/basic
    or add:
    INCLUDE $(inst_root_with:tools/dfII/bin/virtuoso)/share/cdssetup/cds.lib
    which includes a reasonable set of default libraries.
  • David0618
    Andrew,
    This worked! Thanks so much. I must have missed this in the documentation somewhere - would you happen to remember which section I might find this in, out of curiosity? I am poring over "Library Manager -> Help -> Contents" now, but if you happen to recall the appropriate chapter, please let me know.
    David
    David,
    I'm not sure this is exactly covered in the documentation. It certainly wouldn't be under the library manager (I would have thought) because it's just a specific example.
    If you start in a fresh directory (no cds.lib) and create a library in Virtuoso, it will create a local cds.lib with:
    SOFTINCLUDE /export/home/apps/IC617_isr/share/cdssetup/cds.lib
    DEFINE mylib /export/home/myusername/support/testit/mylib
    The first path is essentially what I suggested you include, but I added the $(inst_root_with...) syntax to make it relocatable. If you search in cdnshelp for inst_root_with you'll find info on that syntax in the Cadence Application Infrastructure Guide.
  • David0618
    Andrew, I found the Cadence Application Infrastructure User Guide you mentioned - I will look into it. Thanks again.
