  3. ADEXL Direct Plot error
  • Views 16550
PNadeau
PNadeau over 9 years ago
Hi Folks,
I am having some strange trouble with Direct Plot in ADEXL (Results Tab -> Right click somewhere on a result -> Direct Plot -> Main form)
It goes like this:
1) I click Direct Plot -> Main Form and the form does not appear, when I check the CIW I get this error:
*Error* substring: argument #1 should be either a string or a symbol (type template = "Sx") - nil
2) I click Direct Plot -> Main Form again, this time the form appears, but I am not able to plot anything.  I try various results, click on various nets and terminals, but nothing plots
3) I exit the form and click Direct Plot -> Main Form again, and now it works properly.  Basically third time is the charm
It might be something in my setup, but I'd be awful grateful if someone knows what it is or what to check...
Thanks in advance,
Phil
  • PNadeau
    IC 6.1.7-64b.78, RHEL 6
  • Frank Wiedmann
    Frank Wiedmann over 9 years ago
    This version is the IC617 base release. If you can, I would suggest that you use a later ISR (ISR6 is current) as the earlier versions had quite a number of issues (see the README.txt file under https://downloads.cadence.com/ESDWeb/ReleaseDetail.eo?methodToCall=viewReleaseDetail&platform=LINUX&releaseName=IC617 for details).
  • PNadeau
    Thanks very much. I will ask about upgrading and I can report back if this is fixed in the new version.
  • PNadeau
    We upgraded and this is fixed. Thanks for the pointer!
