  3. Verilog IN error
  • Views 18047
Verilog IN error
magarwal
magarwal over 9 years ago
I am importing a synthesized verilog file using the CIW menu File -> Import -> Verilog. The import fails, and the verilogIn.log file displays the following 2 lines only:
ERROR (VERILOGIN-540): visadev load failed
INFO (VERILOGIN-206): End of Logfile
Any thoughts?
    This looks like this support solution. From that, I suspect you have mixed versions of tools in your UNIX $PATH - some where you've including the "tools/inca/bin" path from some stream in your path.
    You didn't mention any tool versions used.
    Can you just post what "echo $PATH" shows? Please provide it exactly, as-is - so I can check if anything looks suspicious.
