  3. netlist generation with SystemVerilog netlister plugin
  • Subscribers 126
  • Views 14902
jach78
jach78 over 9 years ago
Hi All,
I don't know how to force the netlister to not use positional convention when instantiating modules. I would like the netlister to use the explicit mapping of the signals:
example
I would like to have:
cellname inst_name(.sig1(net1),.sig2(net2));
and not
cellname inst_name(net1,net2);
I have tried the "Netlist Explicitly" option. I tried the "Generate Pin Mapping" option. But nothing happens.
Thanks in advance,
Jack.
    Jack,
    I suggest you contact customer support. Netlist Explicitly should do this - but maybe there is some complexity in your data which is causing this to not work - so we'd need to see it. Or you may be clobbering the setting in the .simrc file, say.
  • jach78
    I was not able to locate my .simrc file. I thought it was automatically managed by the netlister user interface configuration. Am I wrong?
    What do you mean for "clobbering"?
    Best regards,
    Jack.
    Hi Jack,
    The netlister UI creates a file called "si.env" in the run directory with the netlister settings, but if these have been overridden in a .simrc (which could exist in various places - working dir, home dir, <ICinstDir>/tools/dfII/local - and potentially others if CSF has been enabled for .simrc - try typing "cdswhich -all .simrc" and "cdswhich -lookupconfig .simrc") - that's what I meant by "clobbering'.
    That's why I suggested going to customer support - that way we can have a far more interactive discussion to look at your setup and specific situation to understand why it isn't working.
