  3. default editor for system verilog file
  • Views 18368
SteveRFIC
SteveRFIC over 9 years ago
I need to edit some systemVerilog files in cadence.
Currently when I open the file for edit, cadence uses systemVerilog to open it, which is not very convenient to use.
So I want to use a different text editor to edit they systemVerilog files, like gedit or some others, how can I do that? When I choose open with, I also only have the systemverilog option, as shown below:
How can I change the default editor for systemVerilog?
Thanks!
  • SteveRFIC
    changing the default editor helps. By typing the following line in CIW, I can change the default editor to gedit. It also opens verilog code in gedit.
    editor="gedit"
    Which IC subversion are you using? The answer depends on that... (what does Help->About in the CIW state - please post the exact version number it gives there).
  • SteveRFIC
    Andrew,
    Thank you! I am using ic616.isr13.
