  3. Measuring current through subckt
  • Views 16250
roopakvasa
roopakvasa over 9 years ago
I measured subckt current as under
.probe isub(SEGIOX2.VDD)
.probe isub(SEGIOX2.SEGIO0.VDD)
.probe isub(SEGIOX2.REBUF.VDD)
.probe isub(SEGIOX2.SEGIO0.G_IO.VDD)
.probe isub(SEGIOX2.SEGIO0.G_IO.IO_COM.VDD)
.probe isub(SEGIOX2.SEGIO0.G_IO.IO_COM.IO_COM_F_0.VDD)
.probe isub(SEGIOX2.SEGIO0.G_IO.IO_COM.IO_COM_F_0.WRITE0.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_0.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_1.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_2.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_3.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_4.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_5.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_6.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_7.VDD)
.probe isub(SEGARRAYX2.SEG0.BANK_MAX.HBANK.LBL.LBLX4_8.VDD)
I think there is a better way to do the same stuff using save and *lvl command. But i couldnt get the proper syntax.
Can anyone share correct spectre syntax?
    See "spectre -h save" - I think this will explain what you want to know.
  • roopakvasa
    Thanks Andrew.
    Command line help is much better than documentation and it did help me.
