  3. Bindkey for display dimming
  • Views 18534
roopakvasa
roopakvasa over 9 years ago
While using bundkey editor i couldnt get skill command for display dimming.
Can anyone help how to set this bind key?
    This probably depends on what  you're trying to do - there are several controls for dimming. If it's just enabling/disabling dimming, then you could use:
    hiGetCurrentWindow()->dimmingOn=t
    or
    hiGetCurrentWindow()->dimmingOn=!hiGetCurrentWindow()->dimmingOn
    if you want to toggle it. Using the Help button on the Options->Display form will allow you to find the dimming options, and this mentions the env var names; you can typically use the env var names as properties on the window object to control it for the current window.
  • roopakvasa
    Thanks Andrew,
    The issue was rather more trivial. My cds.env was linked to a file which I could not overwrite. So my setting were not getting saved. Make a local copy of cds.env and issue solved.
    I don't see how a non-writable .cdsenv would have anything to do with a bindkey definition, but if you're happy with your solution fair enough! (perhaps you solved the reason for needing the bindkey in the first place - you didn't say that in your original post).
