  3. Unsolved step response problem in Spectre transient sim...
  • Views 17572
Unsolved step response problem in Spectre transient simulation
ringamplifier
ringamplifier over 9 years ago
Hi guys!
I am currently designing a current feedback instrumentation amplifier (CFIA), which is shown in Fig. 1. In this amplifier, Gm2 is the input stage, Gm3 is the feedback stage and Gm1 is the output stage. The gain of this amplifier is set by the feedback resistor R1 and R2 (assume that Gm2=Gm3), which is (R1+R2)/R2. The value of the gain is 50 V/V in my case.
        Fig. 1
Now I want to test the step response of this amplifier. So I insert a vpwl voltage source V1 between the two input of Gm2.  V1 will generate the voltage step and ideally Vout will produce a amplified version of the step.
The setting of V1 is:
Time 1  Voltage1
   0s           0V
Time2   Voltage2
  1ns         40mV
Time3    Voltage3
100ns      40mV
The simulation result of Vout is plot in Fig. 2. Unexpectedly, something like ringing happened
        Fig. 2
But I changed the Time 2 to 50ns, the Vout seems normal again. Result is shown in Fig. 3
Time 1  Voltage1
   0s           0V
Time2   Voltage2
  50ns         40mV
Time3    Voltage3
100ns      40mV
        Fig. 3
I hope anyone can give me  a hand! Thanks!
  • Mikexay
    Mikexay over 9 years ago
    here:
    community.cadence.com/cadence_technology_forums/f/38/t/22633
    Learn Vietnamese online( free for all cadence's members ):
    Lession 1: nho ninh thuận
  • ringamplifier
    Thanks!
    I solved the problem since I found the instability of the internal circuit.
