  3. Significant digits in tables generated by ADE L calcula...
  • Replies 11
  • Views 27066
Significant digits in tables generated by ADE L calculator
Aldo2
Aldo2 over 9 years ago
I would like to set 16 as the number of significant digits in the tables created through calculator from a waveform.
Any suggestion?
Thank you
Best Regards
Aldo
    In the table, select the column you want to increase the number of digits (just click on one of the values in the column) and then do View->Format and you can increase the number of digits there. By the way, 16 digits is a bit excessive - that's beyond the precision (just) of double precision floating point numbers, and certainly beyond the simulator accuracy. It's probably unlikely you'd get much benefit beyond about 9 or 10 digits, I'd say.
  • Aldo2
    Thank you Andrew,
    Is there a way to set the new value as a default? A skill setting to insert in the .cdsinit?
    Thank you very much
    Aldo
    Aldo,
    Yes.
    envSetVal("viva.table" "significantDigits" 'string "12")
  • Svilen Mintchev
    Svilen Mintchev over 5 years ago in reply to Andrew Beckett
    Is there a way to change the number of significant digits for the expression results in the outputs section of ADE L? Changing the digits for the table doesn't seem to have any effect here.
    ShawnLogan over 5 years ago in reply to Svilen Mintchev
    Dear Svilen,
    As you may know, ADE-L is no longer supported. Hence, it might be worth considering to ADE Explorer/Assembler. Explorer is the "ADE-L" replacement and has a lot more features.
    In any case, in response to your question, have you seen this article?
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXCdEAM&pageName=ArticleContent
    Shawn
  • Svilen Mintchev
    Svilen Mintchev over 5 years ago in reply to ShawnLogan
    Hi Shawn,
    The commands in the link work, thanks a lot.
    On a similar token, where can I find the math functions allowed to be used in composing design variables in ADE L? I know simple addition, subtraction, multiplication and division work fine, but what about something more complicated than that? For example, can I use the same math functions and syntax as the functions in the calculator?
    Svilen
    Dear Svilen.
    Great!
    Are you actually referring to design variables or expression based outputs? In the case of expression based outputs, the functions defined in the calculator will work in output expressions. I do not know of a specific list of functions that are defined for use in ADE-L design variables. ADE Explorer and Assembler do provide design variable functions that, for example even allow one to pass the results from one simulation result as a design variable to a subsequent simulation.
    Shawn
  • Svilen Mintchev
    Hi Shawn,
    I was referring to the design variables. I need to create a variable that's a log2 of another variable.
    Svilen
    Andrew Beckett over 5 years ago in reply to Svilen Mintchev
    Hi Svilen,
    If it's ADE L, then you are limited to expressions which can be passed to the simulator and handle there - so if using spectre, it's the functions listed in "spectre -h expressions" (type in a UNIX terminal). If using ADE Explorer/Assembler, you can also use SKILL functions.
    In either case there's no log2 in SKILL or Spectre, so you could just use log(N)/log(2) to get log2(N).
    ShawnLogan over 5 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you, once again, for adding your helpful insight!
    Shawn
