  3. RX-Chain Noise Figure calculation with QPSS
  • Views 17001
Juanelin
Juanelin over 9 years ago
Hi all,
I am currently simulating a receiver chain consistent of an LNA-Balun-Mixer combination using QPSS and QPNOISE as engines. My input port drives the LNA with a 50 Ohm impedance, while the output port serves as 100-Ohm load impedance to the mixer. So far, the gain of the complete Chain seems to correspond to the expectations (GAIN1+GAIN2+GAIN3) but the noise figure happens to be between around 3 dB higher than expected if I plug the single component gain/noise values into the Friis NF equation. I plot the NF using the "Noise Figure" option (SSB) under the QPNOISE results.
I was wondering if this 3 dB difference comes from the 100 Ohm output /50 Ohm input factor due to the single ended to differential conversion? So far I haven't found how the QPNOISE engine calculates the noise figure, but that would be my first guess. The receiver's building blocks are matched among them, 50 Ohm single ended, 100 Ohm for the differential ones, so I would discard at first instance any increase in the noise figure due to mismatch between components.
Any document or explanation would be greatly appreciated.
Thanks a lot,
Erick
  • Tawna
    Tawna over 9 years ago
    Hi Erick,
    1. You didn't mention what version of IC software and what version of Spectre you are using.
    virtuoso -W
    spectre -W
    will give this information. If possible, use IC6.1.7 (latest ISR) and MMSIM 15.1 (latest ISR) from http://downloads.cadence.com .
    2. You mentioned that you are using qpss/qpnoise. Harmonic balance or Shooting Newton? Is the circuit strongly nonlinear (think square waves or more nonlinear)? Then use Shooting Newton. Otherwise use HB/HBnoise.
    3. It's difficult to say without seeing your design. I recommend contacting Cadence Support (http://support.cadence.com) to get help from the Application Engineer on Call.
    4. The Spectre and APS RF User Guide will give a lot of good information on how noise is calculated. I strongly recommend reviewing the noise chapter(s). There are several ways to access it:
    - type 'cdnshelp &' in your xterm
    - go to http://support.cadence.com and search for the Spectre and APS RF User Guide
    - In the hierarchy at <path_to_MMSIM>/lnx86/doc/spectreRF/spectreRF.pdf
    In Appendix A of the Spectreand APS RF User Guide, if I recall correctly, there is an example of a differential mixer that may help you with setup.
    best regards,
    Tawna
  • Juanelin
    Hi Tawna,
    Many thanks for the reply. Please find below some answers to your questions.
    1- I am using IC 6.1.6/6.1.5 and MMSIM 15.1. Hotfix 6.27 I unfortunately cannot use IC 6.1.7 due to current incompatibilities with my PDK.
    2. My circuit is not a strong-nonlinear one. It is basically a LNA+Mixer chain with a single-differential conversion provided by an active balun. The engine I am using is Harmonic Balance with QPSS. Btw, I've already simulated the chain with HB and come to pretty similar results using HBNOISE.
    3. Will try to provide it. I will discuss it with my supervisor.
    4. I've found some information about the noise calculation in the document you mentioned, thanks a lot. I've found the following equations/definitions
    F = (No^2 - Nl^2)/Ns^2
    NF = 10*log10(F)
    where Nl = Noise at the output due to the output probe, Ns = Noise at the output due to the input probe, No = Total output noise. So if I understand correct, it is calculated using a typical ratio of power spectral densities (noise voltage square), but this power spectra depends on the actual load resistance vn^2 = 4kTR, where R is different for input (50) and output (100), so there is a factor 2 there that makes the noise figure ~ 3 dB higher. Please correct me if I misunderstood something.
    Many thanks for your help.
    Best regards,
    Erick
