  3. howto disable port-order check for vmsUpdateCellViews ?
  • Views 14458
Emulator
Emulator over 9 years ago
I try to apply SV netlister, so I need to run the vmsUpdateCellViews for systemverilog models (stored on an external repository) before.
As I have to enable the cross-check wrt to symbol and module port consistency (port number and port names), I would like to disable the portOrder check during vmsUpdateCellViews.
Setting following variables didn't help out in IC 6.1.6:
disablePortOrderPopup=nil
vicCheckPinOrder=nil.
As the connections are explicit, the portOrder may be ignored for symbol and systemverilog module.
Do you have any further hints on disabling it ?
Thanks in advance,
Gregor
