  3. changing via using skill
  • Views 15757
GirishBS181
GirishBS181 over 9 years ago
Hi All,
I am trying to write a simple code to change VIA in IC6.1.6.
procedure(viaChange()
foreach(fig geGetSelSet()
  when(fig~>objType=="customVia"
    newMaster=dbOpenCellViewByType(fig~>libName "m2_m1" fig~>viewName)
    fig~>master=newMaster
    dbClose(newMaster)
hiSetBindKey( "Layout" "Shift<Key>1" "viaChange()")
I am getting the following error when I execute this simple code : *Error* setSGq: (DB-370034): dbSetq: Cannot set attribute - master
The master is not getting reset. Can anyone help me resolving this issue?
Is there any better way to write this code?
Girish
    You can't just remaster vias like this; you have to recreate the via using dbCreateVia again - there's no API to replace the master with a different custom (or standard) via. There's a couple of relevant solutions on this:
  • GirishBS181
    Thanks Andrew!
