  3. Symbol line disappear in schematic view
  • Views 16567
happymos123
happymos123 over 9 years ago
I got a special symbol and I tried to modify it.
I created line as symbol shape by symbol editor.
and also create Note->Text in the symbol editor.
The line and text can be seen in symbol editor
but
When I use the symbol in virtuoso schematic editor
all the line and text disappeared in schematic view, why and how to reset  ?
Thank you.
    There's really not enough to go on here - I've no idea what version you're using, whether all lines in symbols are invisible or just your newly added ones (if it was everything, I could anticipate it might be a display.drf problem, but then I'd expect them to be invisible in the symbol editor too). I suggest you contact customer support, as I doubt this is going to be debuggable without seeing it - I've certainly not heard of such behaviour before.
  • happymos123
    Thanks for your kindly reply.
    I found if I copy to different cell name, the line is normal and can be visible in schematic.
    but if I change the cell name, it will not consistent with my spice model.
    JJ
    I have no idea what could cause that. Another reason to contact customer support so that somebody can take a look.
