  3. Assura DRC/LVS error
  • Views 2019
Alpacca
Alpacca over 9 years ago
Hello there,
I'm making an OTA layout in cmhv7sf technology. When I run DRC I get errors that 8 transistors have no body contact, while there are substrate and n-well contacts. Because of thsee errors LVS is failing due to those 8 unmatched transistors.
Thanks in advance for your help!
Here is DRC result:
Here is layout:
  • Quek
    Quek over 9 years ago
    Hi Lidia
    You might want to check the following:
    a. Does the PDK user guide say that you need to manually draw some extra layers to create substrate/well contacts?
    b. Are there any switches in DRC/LVS decks that need to be enabled so that the contacts can be extracted?
    c. Instead of manually adding those contacts, how about enabling the "body tie" option on the mos pcell? If this resolves the problem, check the layers in the automatically created body tie and compare it against your current contacts.
    Best regards
    Quek
