  3. MMSIM Issue with IC5141
  • Replies 11
  • Views 22413
Bilal Porto
Bilal Porto over 9 years ago
I was using IC5141 on CentOS 64bit with MMSIM 12. The problem was that mmsim was defined prior to IC tools. my script looked something like following :
setenv MMSIM_12_11        ~cdsmgr/cad/tools/cadence/mmsim
set path=(    \
    $MMSIM_12_11/bin\
    ${path}\
set path=(    \
    $MMSIM_12_11/tools/bin\
    ${path}\
# Set environmental variables and paths for IC_5.1.41HF151 and tools
set path = (~cdsmgr/cad/tools/cadence/mmsim/bin $path)
setenv  CDS_ROOT                ~cdsmgr/cad/tools/cadence/ic_5.1
setenv     CDS_INST_DIR        ~cdsmgr/cad/tools/cadence/ic_5.1            # Basic Cadence (i.e. IC tools)
setenv     CDSDIR             ~cdsmgr/cad/tools/cadence/ic_5.1            # IC tools (composer, virtuoso, etc.)
setenv     CDS_INSTALL_DIR     ${CDS_INST_DIR}/tools/dfII
setenv     CDSHOME         $CDS_INST_DIR
setenv     EDI               ~cdsmgr/cad/tools/cadence/edi9.12            # SOC Encounter place and route
#setenv IUS               $base_dir/IUS-F08                    # Verilog simulators
setenv     ETS               ~cdsmgr/cad/tools/cadence/ets9_1            # Encounter Library Characterizer, Timing
setenv     ET               ~cdsmgr/cad/tools/cadence/ets9_1            # Encounter Test system
setenv     RC                ~cdsmgr/cad/tools/cadence/RC             # RTL Compiler synthesis
set path=(    \
    $CDS_ROOT\
    $CDS_ROOT/tools/spectre/bin\
    $CDS_INST_DIR/bin\
    $CDS_INST_DIR/tools/bin\
    $CDS_INST_DIR/tools/dfII/bin\
    $EDI/bin\
    $ETS/bin\
    $ET/tools.lnx86/bin\
    $RC/bin\
    ${path}\
It apparently was working fine but when i checked with command spectre -W, it showed sub-version  5.10.41.121508 .
Now if i define MMSIM path after IC tools, i get in terminal for spectre version sub-version  12.1.1.096.isr12
but in CIW, it is giving error.
I understand that this problem is coming from mmsim/bin/cds_root. but cannot understand why. Please help me with it.
    Your use of "before" and "after" is a bit counter to the usual way of describing this (which is whether the path to MMSIM is before or after the path to IC in the $path variable). Because you're prepending paths in the two updates to the $path variable, that's why your terminology was a bit back to front. Anyway, the key is that with IC5141 you really need to have the MMSIM path before the IC path in the $path variable, which is what your second update did.
    Unfortunately there was no image in the post above, so I can't see the error. Can you just paste the text of the CIW error rather than posting an image?
  • Bilal Porto
    Thanks Andrew for your reply. Once i run the scripts,it loads CIW but there error reads:
    "cds_root: the tool is not available on lnx86 platform. unable to find cadence installation"
    I am not able to open library editor. but i can open my cell views and things but cannot run simulations.
  • Bilal Porto
    Dear Andrew. Please find following log:
    \o Program: @(#)$CDS: icfb.exe version 5.1.0 11/22/2011 01:38 (cicln04) $
    \o Hierarchy: /home/cdsmgr/cad/tools/cadence/ic_5.1/tools.lnx86/dfII/
    \o Sub version: sub-version 5.10.41.500.6.151 (32-bit addresses)
    \o Host name (type): I02CP2201@fe.up.pt (x86_64)
    \o Operating system: Linux 2.6.32-642.6.1.el6.x86_64 #1 SMP Wed Oct 5 00:36:12 UTC 2016
    \o X display name: :0.0
    \o X server: CentOS
    \o Depth of Visual (Root): 24 (24)
    \o Number of Planes Used: 24
    \o X version: 11.0 (vendor release 11704000)
    \o Window Manager: other
    \o User Name: NASA
    \o Working Directory: I02CP2201@fe.up.pt:/home/NASA/projects
    \o Process Id: 4563
    \o
    \o COPYRIGHT © 1992-2009 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
    \o © 1992-2009 UNIX SYSTEMS Laboratories INC.,
    \o Reproduced with permission.
    \o
    \o This Cadence Design Systems program and online documentation are
    \o proprietary/confidential information and may be disclosed/used only
    \o as authorized in a license agreement controlling such use and disclosure.
    \o
    \o RESTRICTED RIGHTS NOTICE (SHORT FORM)
    \o Use/reproduction/disclosure is subject to restriction
    \o set forth at FAR 1252.227-19 or its equivalent.
    \p >
    \o 8-bit PseudoColor Visual is not available (default Visual option).
    \o Using 24-bit TrueColor Visual.
    \o The program xdpyinfo can be used to verify the Visuals available
    \o for your display.
    \o Loading PRshare.cxt
    \o Loaded the PVS environment.
    \o Loading LVS.cxt
    \o Loading layerProc.cxt
    \o Loading ams.cxt
    \o Loading acv.cxt
    \o Loading auCore.cxt
    \o Loading schView.cxt
    \o Loading selectSv.cxt
    \o Loading seismic.cxt
    \o
    \o //
    \o // Calibre Skill Interface * (v2013.4_15.12) *
    \o //
    \o // Copyright Mentor Graphics Corporation 2005
    \o // All Rights Reserved.
    \o // THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
    \o // WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
    \o // OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
    \o //
    \o //
    \o END OF USER CUSTOMIZATION
    \o Loading oasis.cxt
    \o Loading analog.cxt
    \o Loading /home/NASA/Desktop/ADS2011/idf/skill/5.1.0/ads.cxt
    \p >
    \o Loading spectrei.cxt
    \o Loading spectreinl.cxt
    \o Loading hspiceD.cxt
    \o Loading msgHandler.cxt
    \o Loading UltraSim.cxt
    \o Loading AMSOSS.cxt
    \o Loading AMS.cxt
    \o Loading apsi.cxt
    \o cds_root: ERROR: The tool 'cds_root' does no_t seem to be available on the
    \o cds_root: platform 'lnx86' in your installation:
    \o cds_root: '/home/cdsmgr/cad/tools/cadence/mmsim'
    \o Unable to find the Cadence software in your $PATH.
    \o Please fix this and try again.
    I've not seen this behaviour - but then again you have some unnecessary paths in your $path. All you should need is:
    MMSIM/bin
    IC/tools/bin
    IC/tools/dfII/bin
    you have numerous others which shouldn't be needed. Perhaps you can also post the output of:
    ls ~cdsmgr/cad/tools/cadence/mmsim
    I tried reproducing it on an RHEL6 machine (with similar versions) and all worked OK for me. You may be best advised to contact customer support so that we can have a webex with you to take a look - doing this via the forums is hard as it has a slow round trip time!
  • chanakaya
    chanakaya over 9 years ago
    I also want to clarify that you have a very good reason for running these really old versions of our tools. Otherwise, you will have much better luck with newer versions.
  • Bilal Porto
    Thanks Andrew for your time. Here is the output of mmsim folder:
    [NASA@I02CP2201@fe ~/projects]$ ls ~cdsmgr/cad/tools/cadence/mmsim/
    bin install share
    data installData tools
    doc installer_vars.properties tools.lnx86
    Hotfix_MMSIM12.11.096_lnx86.sdp iscape_logs
    ic_index.sdx oa_v22.43.015
    I am now taking the back up and planning to reinstall. if you find something in the mean time, it would be great.
  • Bilal Porto
    yes my only fear is change. I am at a very critical stage of my chip and don't want to risk it with a newer version with which i do not have much experience.
    Although I'm not sure why you're worrying about changing version when the version you have isn't actually working for some reason!
  • Bilal Porto
    what i meant is that iC6 looks a bit different. U know i feel a bit uncomfortable with tabs misplaced or some extra tabs which i don't know the meaning. but let me ask you one favour. which parasitic tool is good for extracting self inductance and mutual inductance i.e Assura QRC or Calibre. can you please provide a short tutorial in setting up calibre and assura specifically for indutance. I found alot of help for capacitance and resistance. but still i am not clear for inductance. if this has already been discussed in another thread, please provide the link. Thanks
    QRC can extract RLCK and is very capable in that area. Also, "U" is spelt "you" (there's no tax on characters in the forums - see the end of the forum guidelines - this is something that irritates me and makes it less likely that I'll respond, for future reference...)
    If you want to extract L and K in QRC, simply pick that extraction mode on the form (e.g. RLC or RLCK). I can't provide you a tutorial for Calibre (it's not a Cadence tool - it's from Mentor Graphics) and the documentation for QRC should really be sufficient here
