  3. find out which SKILL function is called in the backgrou...
  • Subscribers 133
  • Views 15924
find out which SKILL function is called in the background
sunilm123
sunilm123 over 9 years ago
I have a schematic , where if I select any of the instance and press Q (Edit Object properties)  ,  some function is getting called (Internal customization)  and it does the check n save of that schematic.
I am trying to figure out which function is called.
I have tried setting sstatus debugMode t  and sstatus stacktrace t , also enabled all the "log filters"  but that didn't help .
Is there any other pointers which I can try .
    The brute force way would be to use trace(t) . I would probably adopt some more refined tracing myself, but then again I'd probably need to understand exactly at which step it occurred. I might start with tracing the schematic extraction type functions:
    trace(schExtractConn schCheck)
    and then if these show up as being triggered, I might then set breakpoints on them (using breakpt), invoking the command that triggers it, and then typing "where" in the CIW to find out the stack trace at the point the debugger has kicked in (type continue() to continue from the breakpoint).
  • sunilm123
    Thanks Andrew . It was helpful.
