  3. rise/fall time calculator result not in accordance with...
  • Views 1676
rise/fall time calculator result not in accordance with waveform calculation
rakesh2485
rakesh2485 over 9 years ago
I am working on Cadence IC6.1.5-64b.500.17
My rise time/fall time calculator results are not same as the ones calculated from the waveform.
I looked through few posts and followed the procedure, but I am still not able to figure out the issue.
Could it be a bug? should I go for developing SKILL scripts?
Please help,
Rakesh
    I read through your post and couldn't figure out the issue you're actually facing. I doubt anyone could. If you want help, you really need to provide sufficient detail for somebody to be able to understand the problem (see the Forum Guidelines which explains this).
